by: technicavivunt
#50278
Ok, so I'm relatively new to AMD. I'm looking around for a possible patch. I tried the external patch from PikeAlpha with no success. But long story short all of my drives (both NVMe and SATA) except one (MP500 NVMe in the second slot) show up as external drives. Apart from that, everything has been fantastic.
by: kegman
#50312
it is only cosmetic but I use this kext to make external to internal. same issue with my Samsung 970 pro.
let me know how my goes...
#50315
kegman wrote: Tue Jul 23, 2019 11:01 pm it is only cosmetic but I use this kext to make external to internal. same issue with my Samsung 970 pro.
Perfection! Literally my only gripe solved!
by: kegman
#50329
:thumbup:
Good question: I've extracted the Titan Ridge[…]
Could you share your new efi to me, thank you!My[…]
Big thanks to Anti for publishing his EFI Folder. […]
Any updates on Protools running on an AMD Hackinto[…]
