by: Lightprolife
#50156
Hello, I wanted to install the OS, but it does not work.
PC specifications:
Ryzen 2600
MSI B450-A-PRO
RX 580 8gb
I found a post from Vanilla, the installation started, but then after restarting it all over again, an apple does not appear
The installation has started, but when the disk utility appears, go to reboot.
linjay38 liked this
by: Dayat
#50271
I also have the same problem.
Ryzen 2600
MSI B450M PRO-VDH PLUS
RX 570 8gb
Thought my experience would be a positive addition[…]
https://forum.amd-osx.com/viewtopic.php?f=61&am[…]
I need your advice
What MacOS, is it better for me to establish that […]
Comp Check
Hello forum, I have a build with the following co[…]
