#50143
Hey guys:
I have a 'fully' functional hackintosh at this point: Wi-Fi, sleep/wake, 3rd party apps, Facetime and imessages, etc. but I still can't get my Bluetooth to work!!! I installed the Fenvi Wireless card which is natively recognized by macOS, but I can't get the bluetooth functionality to work. Link to the wireless card is here - https://www.newegg.com/fenvi-fv-t919-pc ... 00JK-00033
I've attached my EFI to this post. Has anyone been to able bluetooth functionality on their build?
Thanks!
Stans_EFI.zip
#50144
Try with this config.
#50145
Nope, it didnt work. The bluetooth module on the card connect to the USB 2.0 header on my MOBO. I've read that some hackintosh builds have issues with usb 2.0. any suggestions?
#50147
Can you share an IOReg please.
https://files.amd-osx.com/IOReg.zip
#50153
my bcm943602cs didn't apper in the parts of bluetooth and USB of system report before I add three usb patches to my config . But it was plug in usb 3.1 .
#50154
Which patches did you use? Could you share them please?
Which OS X is compatible to AMD A8 7600
You can but you are not going get any graphic acce[…]
Help with Mojave 10.14.6
Okay ill attach it to my message Thanks Sebast[…]
FX 4130?
The installer is a recovery medium. It'll download[…]
Hi. After I used this script and removed USBInjest[…]
