#50087
Try adding the boot flag -radvesa
by: uridi0t
#50096
Anyone know is there a kext that is for RX580?
Shaneee wrote: Sun Jul 07, 2019 2:22 pm Try adding the boot flag -radvesa
I tried adding the boot flag -radvesa with and without checking DeInit but the loading stops as below image.
https://imgur.com/a/uo7mlmC
Really no clue how to boot into installer tho! Any kext made for RX580?
#50109
RX 580 is supported natively by macOS… Installer may be corrupt as I see a prelinked issue there. Try rebuilding the USB.
by: matheusmm
#50122
try replacing FakeSMC.kext with VirtualSMC.kext
some people had success with it.
by: uridi0t
#50124
Shaneee wrote: Tue Jul 09, 2019 2:06 pm RX 580 is supported natively by macOS… Installer may be corrupt as I see a prelinked issue there. Try rebuilding the USB.
Ok, I think you were right that the USB installer is corrupted. It was because something wrong when unzipping the zip file (10.14.4), 7z advised that "32-bit overflow in headers".
I downloaded the file couple of times and still has the unzip problem. Do I have other links to download 10.14.4 or 10.14.5?
If I create 10.14.1 USB installer, installer stops as below without further action:
https://imgur.com/a/Dqrm02C
[/quote]
Thanks! I will try once I create the USB installer again.
This time I follow this guide (https://vanilla.amd-osx.com) to create USB installer but it still turns to blackscreen (with backlight on).
For replacing FakeSMC.kext with VirtualSMC.kext, I put VirtualSMC.kext to Kexts > Other on the boot USB, do I have to edit config.plist in order to use this kext?
#50146
What brand is your RX580? If you want to try VirtualSMC then you need to remove FakeSMC and put VirtualSMC.kext in the kext folder and VirtualSMC.efi in the drivers64UEFI folder.
by: uridi0t
#50148
Shaneee wrote: Thu Jul 11, 2019 3:52 pm What brand is your RX580? If you want to try VirtualSMC then you need to remove FakeSMC and put VirtualSMC.kext in the kext folder and VirtualSMC.efi in the drivers64UEFI folder.
I use Radeon RX 580 ARMOR 8G OC.
I have used OpenCore 0.5.2 with installing Catalin[…]
But, wich version of Catalina worked with you?[…]
I have a very similar configuration. I keep gettin[…]
Hello today I decided to update my system after a […]
