by: Chad
#545
USB-Fix for El Capitan and Sierra Specifically for ASUS motherboards but should work on others too.
Downloads:
- Kext Wizard
http://www.insanelymac.com/forum/topic/253395-kext-wizard-easy-to-use-kext-installer-and-more/
- Shaneee's USB Fix
http://amd-osx.com/files/Shaneee_Sierra_USB_Fix.zip
- RehabMan's Generic USB Kext
https://bitbucket.org/RehabMan/os-x-generic-usb3/downloads
Steps:
1. Open Kext Wizard
2. Select Your USB as target disk (If you didn't rename your USB it's most likely called "OS X Base System")
3. Go to the "Installation" tab, browse and select the kexts you downloaded
4. Click open and select "/System/Library/Extensions"
5. Click Install, once install completes open the "Maintenance" tab
6. Check every box and click "Execute"
7. Once the permissions have been repaired, eject your USB, boot into the installer, and your mouse should work!
Extra.zip
Thanks to Spakk and Shaneee for the files.
by: johansen
#1550
i only have source of OS 10.11.4 with build 15E65, do you have fix for these build? my motherboard using M4A785TD-V EVO. i can only manage to use the USB port for transfering data using option disable USB 2.0 at BIOS level.
by: Valkiry
#3520
Download Fix_V2 For 10.11.1 -> 10.11.4
by: Valkiry
#4147
Chad don't forget to mention the kext removal for the fix :)
by: achamate
#4644
I use clover, then I should use USBFix in ACPI?
#4647
achamate wrote:I use clover, then I should use USBFix in ACPI?
You can try but not sure if it's enough.
by: mhshakouri
#7265
@Shaneee,
Which usb fix would you suggest, Chad's or Yours?
by: Valkiry
#7267
mhshakouri wrote:@Shaneee,
Either or. As you don't know what will work for you
by: mhshakouri
#7273
Can you send me the link to the installation only via keyboard ?
My PS/2 keyboard is not working, but I have a wireless keyboard, which does have a touchpad too, but only the keyboard works. I've made it to disk utility, but that's the most point I could make it on my own.
by: Valkiry
#7274
Just download Shanes V2 Image off the tools section
Mojave Vega 56 OpenGL
Hey there, i'm currently setting up a hackintosh a[…]
meals meals, and fat, it is likely that insufficie[…]
Mate, I got that booting issue +++++++++++ fixed[…]
You have to start by locating a humdrum Boost Ener[…]
