#48045
specs:
Ryzen 5 1600x
Asus prime b350 plus
8gb corsair ram
So I installed High Sierra successfully a few days ago and everything has been working pretty well. I was backing up some files and i needed to cancel it and it wouldn't stop copying so i relaunched the Finder. The screen went black with just the curser showing. I restarted the computer and now it won't boot to either the hard drive or usb i sed to install it.
Is it something with the bios that has caused this? It does sometime show a bit of code before the system restarts which can be seen below.
Thanks
It's ok i fixed it :)
Shaneee's AMD Build
@Shanee Could you please share me your clover conf[…]
audio stuttering issue
Ryzen 2700x MSI B450m mortar Asus R580 Audio wor[…]
Unable to set Clover Theme
Thanks for replying XLNC :thumbup: I'm familiar […]
I now notice this statement at the NoVPAJpeg repos[…]
