by: Furiel
#47671
Hi guys,
I successfully installed Mojave on Ryzen 1700, with Radeon 7950 3Gb video card and 16G of ram, the only problem is when i reboot the system i get the window warning that the Mac wasn't shut down correctly, stacktrace is below.
Can you guys help me to fix this?
Thanks.
Anonymous UUID: 08A6536C-C913-E2AB-D27D-CF97D59F0114
Sat Apr 27 16:14:46 2019
*** Panic Report ***
panic(cpu 8 caller 0xffffff8019043bf2): "Wired Keyboard 600[0x100000325]::terminate(kIOServiceSynchronous) timeout\n"@/Users/shaneee/Desktop/xnu-4903.221.2/iokit/Kernel/IOService.cpp:2333
Backtrace (CPU 8), Frame : Return Address
0xffffff9220bd3940 : 0xffffff80189fc36d mach_kernel : _handle_debugger_trap + 0x44d
0xffffff9220bd3990 : 0xffffff8018b4efa3 mach_kernel : _kdp_i386_trap + 0x153
0xffffff9220bd39d0 : 0xffffff8018b3fa72 mach_kernel : _kernel_trap + 0x5f2
0xffffff9220bd3a40 : 0xffffff801899cc90 mach_kernel : _return_from_trap + 0xe0
0xffffff9220bd3a60 : 0xffffff80189fbdf7 mach_kernel : _panic_trap_to_debugger + 0x197
0xffffff9220bd3b80 : 0xffffff80189fbc43 mach_kernel : _panic + 0x63
0xffffff9220bd3bf0 : 0xffffff8019043bf2 mach_kernel : __ZN9IOService23scheduleTerminatePhase2Ej + 0x242
0xffffff9220bd3c50 : 0xffffff801904773d mach_kernel : __ZN9IOService15terminatePhase1Ej + 0x92d
0xffffff9220bd3cd0 : 0xffffff7f99968776 com.apple.iokit.IOUSBFamily : __ZN11IOUSBDevice9terminateEj + 0x21a
0xffffff9220bd3cf0 : 0xffffff7f9a694ee3 com.apple.driver.AppleUSBLegacyHub : __ZN21AppleUSBLegacyHubPort12RemoveDeviceEv + 0x3cb
0xffffff9220bd3d30 : 0xffffff7f9a6948bf com.apple.driver.AppleUSBLegacyHub : __ZN21AppleUSBLegacyHubPort4stopEv + 0x60d
0xffffff9220bd3d90 : 0xffffff7f9a689dbb com.apple.driver.AppleUSBLegacyHub : __ZN17AppleUSBLegacyHub9StopPortsEv + 0x14b
0xffffff9220bd3dd0 : 0xffffff7f9a68cb81 com.apple.driver.AppleUSBLegacyHub : __ZN17AppleUSBLegacyHub14HubPowerChangeEm + 0xd5
0xffffff9220bd3e20 : 0xffffff8019056b38 mach_kernel : __ZN9IOService19driverSetPowerStateEv + 0x178
0xffffff9220bd3ea0 : 0xffffff80190568ea mach_kernel : __ZN9IOService15pmDriverCalloutEPS_ + 0x2a
0xffffff9220bd3ec0 : 0xffffff8018a404b5 mach_kernel : _thread_call_delayed_timer + 0xf65
0xffffff9220bd3f40 : 0xffffff8018a40065 mach_kernel : _thread_call_delayed_timer + 0xb15
0xffffff9220bd3fa0 : 0xffffff801899c0ce mach_kernel : _call_continuation + 0x2e
com.apple.iokit.IOUSBFamily(900.4.2)[102E3905-A575-3F55-A481-6D85E9334AEB]@0xffffff7f9992b000->0xffffff7f999c5fff
dependency: com.apple.iokit.IOPCIFamily(2.9)[7DE930EC-AB73-3F5A-9D38-94D5EE90D197]@0xffffff7f99286000
dependency: com.apple.iokit.IOUSBHostFamily(1.2)[922E7520-229B-3C68-B232-A8727A20D44D]@0xffffff7f9987f000
dependency: com.apple.driver.usb.AppleUSBCommon(1.0)[3C048DDF-4E3F-3603-B95B-5580F5A93F06]@0xffffff7f99877000
com.apple.driver.AppleUSBLegacyHub(900.4.2)[AA5452D1-B604-3119-AF24-751C0FAAF679]@0xffffff7f9a687000->0xffffff7f9a6a4fff
dependency: com.apple.iokit.IOUSBFamily(900.4.2)[102E3905-A575-3F55-A481-6D85E9334AEB]@0xffffff7f9992b000
BSD process name corresponding to current thread: kernel_task
Boot args: kcsuffix=amd keepsyms=1 npci=0x3000
Mac OS version:
18B75
Kernel version:
Darwin Kernel Version 18.2.0: Sat 12 Jan 2019 20:18:25 GMT; root:xnu-4903.221.2/BUILD/obj/RELEASE_X86_64
Kernel UUID: 4305175F-CC02-322A-871E-7B9C6039385C
Kernel slide: 0x0000000018600000
Kernel text base: 0xffffff8018800000
__HIB text base: 0xffffff8018700000
System model name: iMac14,2 (Mac-27ADBB7B4CEE8E61)
System uptime in nanoseconds: 456682302493
last loaded kext at 373032836483: com.apple.filesystems.msdosfs 1.10 (addr 0xffffff7fa0380000, size 69632)
last unloaded kext at 328733214383: com.apple.filesystems.msdosfs 1.10 (addr 0xffffff7fa0380000, size 69632)
loaded kexts:
com.metakine.handsoff.driver 4.0.2
com.insanelymac.RealtekRTL8111 2.2.1
org.voodoo.driver.VoodooHDA 2.9.0d7
net.osx86.kexts.GenericUSBXHCI 1.2.11
org.netkas.FakeSMC 3.5.0
as.vit9696.WhateverGreen 1.2.6
as.vit9696.Lilu 1.3.2
org.tgwbd.driver.NullCPUPowerManagement 1.0.0d2
com.apple.driver.AppleUpstreamUserClient 3.6.5
com.apple.driver.AppleMCCSControl 1.5.6
com.apple.kext.AMDFramebuffer 2.0.2
com.apple.fileutil 1
com.apple.filesystems.autofs 3.0
com.apple.filesystems.ntfs 3.13
com.apple.driver.AirPort.BrcmNIC-MFG 1400.1.1
com.apple.kext.AMDRadeonX4000 2.0.2
com.apple.AGDCPluginDisplayMetrics 3.25.6
com.apple.driver.AppleHV 1
com.apple.iokit.IOUserEthernet 1.0.1
com.apple.iokit.IOBluetoothSerialManager 6.0.9f2
com.apple.driver.AirPort.BrcmNIC 1400.1.1
com.apple.kext.AMD7000Controller 2.0.2
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.AppleOSXWatchdog 1
com.apple.driver.AppleIntelSlowAdaptiveClocking 4.0.0
com.apple.driver.ACPI_SMC_PlatformPlugin 1.0.0
com.apple.driver.AppleVirtIO 2.0.9
com.apple.filesystems.hfs.kext 407.200.4
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.BootCache 40
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0
com.apple.AppleSystemPolicy 1.0
com.apple.filesystems.apfs 945.220.38
com.apple.driver.AppleUSBLegacyHub 900.4.2
com.apple.driver.AppleAHCIPort 329.200.2
com.apple.private.KextAudit 1.0
com.apple.driver.AppleACPIButtons 6.1
com.apple.driver.AppleRTC 2.0
com.apple.driver.AppleSMBIOS 2.1
com.apple.driver.AppleAPIC 1.7
com.apple.nke.applicationfirewall 190
com.apple.security.TMSafetyNet 8
com.apple.driver.AppleIntelCPUPowerManagement 220.0.0
com.apple.driver.AppleSMBusController 1.0.18d1
com.apple.iokit.IOSMBusFamily 1.1
com.apple.kext.triggers 1.0
com.apple.kext.AMDRadeonX4030HWLibs 1.0
com.apple.iokit.IOAcceleratorFamily2 400.27
com.apple.kext.AMDRadeonX4000HWServices 2.0.2
com.apple.iokit.IOAVBFamily 710.1
com.apple.plugin.IOgPTPPlugin 700.7
com.apple.iokit.IOEthernetAVBController 1.1.0
com.apple.driver.AppleSSE 1.0
com.apple.iokit.IOSurface 255.1
com.apple.iokit.IOBluetoothFamily 6.0.9f2
com.apple.iokit.IO80211Family 1200.12.2
com.apple.driver.mDNSOffloadUserClient 1.0.1b8
com.apple.driver.corecapture 1.0.4
com.apple.kext.AMDSupport 2.0.2
com.apple.AppleGPUWrangler 3.25.6
com.apple.AppleGraphicsDeviceControl 3.25.6
com.apple.iokit.IOSlowAdaptiveClockingFamily 1.0.0
com.apple.driver.IOPlatformPluginLegacy 1.0.0
com.apple.driver.IOPlatformPluginFamily 6.0.0d8
com.apple.iokit.IOGraphicsFamily 530.12
com.apple.iokit.IOUSBHIDDriver 900.4.2
com.apple.driver.AppleUSBComposite 900.4.2
com.apple.iokit.IOSerialFamily 11
com.apple.filesystems.hfs.encodings.kext 1
com.apple.driver.usb.AppleUSBHostPacketFilter 1.0
com.apple.iokit.IOAHCIBlockStorage 301.200.2
com.apple.iokit.IOAudioFamily 206.5
com.apple.vecLib.kext 1.2.0
com.apple.iokit.IOAHCIFamily 288
com.apple.iokit.IOUSBFamily 900.4.2
com.apple.driver.AppleEFINVRAM 2.1
com.apple.driver.AppleEFIRuntime 2.1
com.apple.iokit.IOHIDFamily 2.0.0
com.apple.security.quarantine 3
com.apple.security.sandbox 300.0
com.apple.kext.AppleMatch 1.0.0d1
com.apple.driver.DiskImages 493.0.0
com.apple.driver.AppleFDEKeyStore 28.30
com.apple.driver.AppleEffaceableStorage 1.0
com.apple.driver.AppleKeyStore 2
com.apple.driver.AppleUSBTDM 456.200.8
com.apple.driver.AppleMobileFileIntegrity 1.0.5
com.apple.kext.CoreTrust 1
com.apple.iokit.IOUSBMassStorageDriver 145.200.2
com.apple.iokit.IOSCSIBlockCommandsDevice 408.200.1
com.apple.iokit.IOSCSIArchitectureModelFamily 408.200.1
com.apple.iokit.IOStorageFamily 2.1
com.apple.driver.AppleCredentialManager 1.0
com.apple.driver.KernelRelayHost 1
com.apple.iokit.IOUSBHostFamily 1.2
com.apple.driver.usb.AppleUSBCommon 1.0
com.apple.driver.AppleBusPowerController 1.0
com.apple.driver.AppleSEPManager 1.0.1
com.apple.driver.IOSlaveProcessor 1
com.apple.iokit.IOReportFamily 47
com.apple.iokit.IOTimeSyncFamily 700.7
com.apple.iokit.IONetworkingFamily 3.4
com.apple.driver.AppleACPIPlatform 6.1
com.apple.driver.AppleSMC 3.1.9
com.apple.iokit.IOPCIFamily 2.9
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.pthread 1
com.apple.kec.Libm 1
com.apple.kec.corecrypto 1.0
EOF
Model: iMac14,2, BootROM 135.0.0.0.0, 8 processors, 3 GHz, 16 GB, SMC 2.15f7
Graphics: AMD Radeon HD 7xxx, AMD Radeon HD 7xxx, PCIe
Memory Module: BANK 1/DIMM0, 16 GB, DDR4, 2800 MHz, Unknown, CMK16GX4M1B3000C15
AirPort: Third-Party Wireless Card
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: ADATA SU800NS38, 128.04 GB
Serial ATA Device: ST1000DM010-2EP102, 1 TB
Serial ATA Device: KINGSTON SV300S37A120G, 120.03 GB
Thunderbolt Bus:
Hello=)
I also have the same problem. Ryzen 2600 MSI B450M[…]
Finally, installed High Sierra but i don't know if[…]
So I installed High Sierra on a second partition o[…]
Hey Guys, I followed this guide (https://forum.am[…]
