by: Fy.Fang
#47110
I made a hard disk to boot MACOS according to the tutorial.But when I boot it with clover.The keyboard and mouse cannot be used in the macOS utility interface.I have installed GenericUSBXHCI.kext and USBInjectAll.kext correctly in clover's boot directory.But it still doesn't workAsk for help, is there any solution? :crazy: :crazy:
by: nbishop8
#47170
Try the DummyUSB kexts? It's hard to say without knowing what your system specs are. I would add your system info into the signature. The Dummy kexts will likely work.
Hello everyone, I am trying to install MacOS to my[…]
"I managed to get through that and installed […]
Good question: I've extracted the Titan Ridge[…]
Could you share your new efi to me, thank you!My[…]
