#45921
Hi All,
I have been following this guide "https://amd-osx.com/forum/viewtopic.php ... daca7c2235" and it has worked flawlessly until the actual installation of Mojave where I am not able to move past the error message "Recovery Server Could Not be Contacted". I guess this has to do with internet connection. I am using an ethernet connection as I don't have a wifi card on my build. How do I go past this error. Any inputs will be great. Here is the hardware specification on my build,
Ryzen 7 1700X
MSI B350 PC Mate Motherboard
GSKILL 32GB RAM
Intel M.2 512 GB
Thanks a lot again. This forum is very helpful.
Hi All,
Just a quick update. I was able to move past the "Recovery Server Could Not Be Contacted" error. The entire installation worked like a charm. No issues what so ever. Thanks a lot.
Your hardware configuration looks ok. Check this g[…]
Hi, that sounds great. You've decided to install H[…]
Hi, I'm not sure but seems to me like your install[…]
Hi, you'd better tell us how do you prepare your b[…]
