by: alyssoncanovas
#42575
After I installed all the Snow Leopard pendrive made with the image of this forum, did the post install script, I got in a kernel panic like this one in the picture. I don´t know why ?
by: AlGrey
#42577
skip that .. you will create one later
Having the same issue. Built this hackintosh speci[…]
Thanks so much for the response. I think I will […]
I have the same problem, when i boot from the USB […]
Hi everyone, i have successfully completed my Cata[…]
