- Fri Aug 03, 2018 1:18 am
#42056
This guide will help you get native usb support for all USB ports on Ryzen motherboards. This will fix your issues with DACs/webcams/mics/BT dongles.
MAKE SURE THAT YOU HAVE A WORKING CLOVER ON YOUR USB DRIVE (usb installer you used to install macOS) AS THIS TUTORIAL CAN FAIL. BOOTING WITH THE CLOVER ON THE USB WILL MAKE THE USB PORTS WORK AGAIN (GenericUSBXHCI.kext is in /EFI/CLOVER/Kexts/**).
This patch replaces the old method : viewtopic.php?t=4736
Automated version (thanks XLNC) NOTE : not updated for mojave
Manual version
Credit to Ydeng
Help and Problem Reporting
Attach the following files in a zip file:
- config.plist
- IORegistryExplorer dump (File -> save)
- DSDT.aml (Open DPCIManager (right click ->open). Click on Extract DSDT. Save the file. )
Spoiler:
Manual version
Spoiler:
Code: Select all
https://forum.amd-osx.com/viewtopic.php?f=53&t=4855
https://www.tonymacx86.com/threads/usb-port-limit-patch-for-14-1-14-2.268893/#post-1884395
- config.plist
Code: Select all
login to download tools
OS: MacOS 10.13.3/.6; 10.14.4 ; Windows 10
CPU: AMD Ryzen 5 1600 @3.2 GHz,
MOBO: Gigabyte AB350 Gaming 3,
GPU: XFX RX580 GTS XXX 8GB [GUIDE : http://forum.amd-osx.com/viewtopic.php?f=24&t=2976]
RAM:16GB DDR4 @ 2933 MHz
Ethernet: RealtekRTL8111.kext in EFI/CLOVER/kexts/Other/
USB: Native support https://forum.amd-osx.com/viewtopic.php ... 86&p=42056
Sound: Full native support onboard + GPU audio https://forum.amd-osx.com/viewtopic.php?f=24&t=6043
algrey#9303 @ https://discord.gg/jCNbMX5
