#41175
DEPRECATED : use this instead. viewtopic.php?f=24&t=4986&p=42056#p42056
This guide will help you get native usb support for all USB ports on Ryzen motherboards and replaces the old method (modded GenericUSBXHCI.kext in /EFI/CLOVER/kexts/* viewtopic.php?f=24&t=3587&p=36836#p36836). This will fix your issues with DACs/webcams/mics/BT dongles.
MAKE SURE THAT YOU HAVE A WORKING CLOVER ON YOUR USB DRIVE (usb installer you used to install macOS) AS THIS TUTORIAL CAN FAIL. BOOTING WITH THE CLOVER ON THE USB WILL MAKE THE USB PORTS WORK AGAIN (GenericUSBXHCI.kext is in /EFI/CLOVER/Kexts/**).
1. Delete GenericUSBXHCI.kext, DummyUSBEHCIPCI.kext and DummyUSBXHCIPCI.kext from:
a. EFI/CLOVER/kexts/10.xx or Other (xx is your MacOs version) NOTE : use Clover Configurator (Google it) to MOUNT your EFI folder.
b. System/Library/Extensions/
c. Library/Extensions/
2. Download the tools
https://nofile.io/f/Eg6wg8tQOgC/debugtools.zip
3. Open Kext Wizard (right click ->open).
Check Repair permissions and Rebuild cache and hit Execute.
4. Open DPCIManager (right click ->open).
Click on Extract DSDT. Save the file.
5. Open the DSDT.aml file you just saved with MaciASL (right click ->open with).
6. Use COMMAND + F and search for "Device (PTXH)"
Should look like this :
                Device (PTXH)
                    Name (_ADR, Zero)  // _ADR: Address
                    Method (_PRW, 0, NotSerialized)  // _PRW: Power Resources for Wake
                        Return (GPRW (0x19, 0x04))
                    Device (RHUB)
Under that block, look for the device with Name (_ADR, One) // _ADR: Address
Should be POT1. Delete that device.
                        Device (POT1)
                            Name (_UPC, Package (0x04)  // _UPC: USB Port Capabilities
                                0xFF,
                                0x03,
                                Zero,
                                Zero
                            Name (_PLD, Package (0x01)  // _PLD: Physical Location of Device
                                Buffer (0x14)
                                    /* 0000 */  0x82, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
                                    /* 0008 */  0x19, 0x0C, 0x80, 0x00, 0x01, 0x00, 0x00, 0x00,
                                    /* 0010 */  0xFF, 0xFF, 0xFF, 0xFF
Do the same with device with Name (_ADR, 0x02) // _ADR: Address
Should be POT2. Delete the device.
                        Device (POT2)
                                0xFF,
                                0x03,
                                Zero,
                                Zero
                                Buffer (0x14)
                                    /* 0008 */  0x99, 0x0C, 0x00, 0x01, 0x01, 0x00, 0x00, 0x00,
Save the edits for that DSDT.aml.
7. Copy the DSDT.aml file to /EFI/CLOVER/ACPI/patched
8. Reboot your PC. Enjoy
Credit to Rio2 for that fix.
https://www.insanelymac.com/forum/topic/334203-ssdt-high-sierra-native-usb-on-ryzen-without-genericusbxhci-or-injector-kexts/?tab=comments#comment-2615950
RagingDemon, SangieWolf liked this
by: 0sk4rgp
#41187
I tried it , deleted the kext, ran kext wizard, and added the edited dsdt, it wasn't working at 1st, then went to xlnc's menu and selected option 5 uninstall usbfix, even thou the files were already deleted, my webcam is finally working thou it has to be connected in a 2.0 port, is an old one.
Thank you!
#41188
There's an issue with this. I have only one USB 2.0 port and it's my USB DAC port. 4 ports on the rear are 3.1 and front two ports I think are 3.0, maybe 3.1. If I use the SSDT method, this method or my own of renaming POT to UHC then all ports work but the rear 3.1 ports act as 2.0. It's the same thing with GenericUSBXHCI. @AlGrey you've got the same board. How are you're ports?
USB	Chipset:
2 x USB 3.1 Gen 2 Type-A ports (red) on the back panel
2 x USB 3.1 Gen 1 ports (available through the internal USB header)
5 x USB 2.0/1.1 ports (1 port on the back panel, 4 ports available through the internal USB headers)
4 x USB 3.1 Gen 1 ports on the back panel
The disconnected device in red was a rear 3.1 port and green is the front 3.0/3.1 port. Rear only shows speeds upto 480Mb/s but front is upto 5Gb/s
by: AlGrey
#41191
@Shaneee, right same thing 2.0 speed only on the ASMedia controller rear ports
@Shaneee, I actually get 2.0 speed on all ports except the two on my case...
I have two usb 3.0 port for my case, they both initialize device POT3/POT7 and POT4/POT8 for USB3.0/2.0 ... but only 2.0 initialization on rear ports.
#41205
AlGrey wrote:@Shaneee, right same thing 2.0 speed only on the ASMedia controller rear ports
I'll keep looking into this when I've got the time. I also noticed that Windows also has the device ID 15E1, 15E0 and 790B for USB. When added to GenericUSBXHCI USB fails to work all together. Maybe some DSDT work is required.
AlGrey liked this
by: tikizondo94
#41282
Excellent work finding this! Worked perfect on my x370 Gigabyte board. All usb 2.0, 3.0 and 3.1 ports seem to be working correctly now. And showing in system profiler. Much appreciated :)
by: ydeng
#41301
tikizondo94 wrote:Excellent work finding this! Worked perfect on my x370 Gigabyte board. All usb 2.0, 3.0 and 3.1 ports seem to be working correctly now. And showing in system profiler. Much appreciated :)
What is your ioreg and dsdt? I get invalid opcode when I try this on x399 board?
by: mexpat911
#41355
I can confirm this fix worked for me. I have about 3 BT devices hooked up, and me C920 is back in business.
This is halfway to a decent hackintosh experience. Just need to get iMessage working now.
Thanks for your post! I'm looking into replacing a[…]
Hello! I've been trying to get my OpenCore configu[…]
Fail. Not worked for nvidia gtx 1070
