#38410
To begin use Transmac to restore the HighSierraV3Unofficial.dmg file to a USB drive, the USB drive needs to be at least 8GBs in size. This tutorial by Shaneee covers using Transmac to restore dmg images to USB: http://forum.amd-osx.com/viewtopic.php?f=24&t=1213. Once you have the image restored you want to boot off the USB drive. You want to select HighSierraAMD to begin. If you get a Waiting on Root Device message, move the USB to a different port for a few seconds to see if the install continues. If it does not then keep moving ports until it does.
Set your SATA ports to AHCI
Enable USB Legacy support and EHCI handoff
Disable your Serial Port
Enable CSM and UEFI for Hard drives and USB devices
Set Secure Boot to Other OS
Select your USB and hit enter
Highlight Boot macOS from HighSierraAMD and press enter
If this is a NEW install highlight Disk Utility and press Continue
Select your Drive from the left side and click the Partition Button on the right to setup your new partition. You want to format it GUID/Extended Journaled.
Once your new partition is created it will show up on the left side under the drive you created it
Click on Reinstall macOS and click Continue
Click Continue
Click Agree
Click Agree again
Select your drive and click Continue
It will begin copying files for a few minutes and restart
Select your USB and press enter
Select Boot macOS from HighSierraAMD
Click Utilities and Open Terminal
Enter cd /Volumes/HighSierraAMD at the prompt
Enter preinstall
Enter your partition name you created earlier
Once it's complete click the Apple Menu and choose Restart
Select your USB drive and hit enter
Select Boot macOS Install from YOURPARTITIONNAME
Soon as it loads the UI it will begin the install, it can take between 20 to 45 minutes depending on your hardware
Once install is finished it will restart
Select your USB drive and press enter
You want to select Boot macOS from HighSierraAMD
Once the UI loads you want to select Terminal from the Utilities menu
You want to enter AMD at the prompt
Enter in your partition name you chose earlier
Once its done it will reboot
Follow the tutorial except for the third boot when you boot to your hard drive for the first time. You want to go to Options - Configs and choose the config_injectATI and add your FakeID to Options - Graphics Injector.
This tutorial will help you figure out your fake ID : http://forum.amd-osx.com/viewtopic.php?f=24&t=2976. This should get you to the desktop.
Booting to desktop
Choose Boot macOS from YOURPARTITIONNAME
Choose your country and click Continue
Choose your keyboard and click Continue
Click Continue
Click on No and click Continue
Click Skip
Click Agree
Click Agree again
Enter you Account information for Login
Click Customize
Click Continue
Click Don't Use
Select your Time Zone from the map
Uncheck all and click Continue
Enable or Disable Siri
Finalizing your Install
If you don't have Clover installed here are some tutorials for different install types depending on your hardware and installation choices. You want to do this while booted off the USB to desktop. You can find the Clover EFI Installer in the Clover Files folder on the Installation USB or you can download Clover EFI from here:
https://sourceforge.net/projects/cloverefiboot/
Clover Configurator is included on the Install USB in the Clover Files folder to use.
Installing Clover for UEFI
Installing Clover Legacy Bios
Installing Clover to a partition with no EFI
http://forum.amd-osx.com/viewtopic.php? ... 494#p31494
Install Extra drivers for Clover with Clover Configurator
Copying the Installers EFI over your Hard Drives EFI
Download HighSierraAMD_V3 Unofficial
http://bit.ly/2KfegS3
#38712
My SSDs and their partitions aren't showing up. What do I need to get them to show up in the disk format utility? I have a PNY SSD2SC24 SSD.
I checked that apfs.efi is already in this image. The rest of my drives show up. :(
I got it to work. I had to convert my extra SSD to a GPT partition in Windows first. Then, it showed up in the list.
This guide works perfectly, but since some of the videos have been removed for Clover, I figured out how to boot without the USB flash drive by following step 6 from here (https://hackintosher.com/guides/macos-h ... lkthrough/):
STEP 6: CONFIGURING THE EFI PARTITION
Now that we’re in macOS we want to be able to load macOS without the USB flash drive plug. To be able to boot macOS from the drive it’s installed on the folder in the EFI partition of the flash drive needs to be copied over to the EFI partition of the boot drive.
Open Clover Configurator
Mount the EFI of the Flash Drive
Press Open EFI or navigate to the EFI location in finder
Copy the EFI Folder onto your desktop
Open Finder and Eject the Flash Drive
Using Clover Configurator Mount the EFI of the Disk
Paste the EFI over the existing EFI on the disk
Select Replace when it prompts you with a menu saying that the folder EFI already exists
I still haven't figured out how to clean up the boot options in Clover, or boot to my legacy Windows partition from Clover, but at least it works! I can just switch between drives I want to boot in the bios for now.
Thank you so much for this detailed guide!
EDIT:
Is there a way to fix the graphics glitches / background colors? I have an Nvidia video card. Attached is a screenshot:
Is this guide accurate for installing Nvidia drivers?
https://hackintosher.com/guides/properl ... rra-10-13/
EDIT:
Got it all working! The above linked guide (https://hackintosher.com/guides/properl ... rra-10-13/) is partially incorrect. NEVER ENABLE SIP with this image! Here's all I had to do:
1. Set config.plist for Nvidia
Mount your EFI partition using Clover Configurator to begin the changes necessary changes to enable Nvidia cards in High Sierra. Here we just need to verify the proper checkboxes are set.
Open Config.Plist using Clover Configurator
In Clover Select Boot under SECTIONS
Uncheck nv_disable=1
Select Graphics under SECTIONS
Uncheck Inject Intel
Select System Parameters under SECTIONS
Check Inject NvidiaWeb
Save config.plist
Exit Clover Configurator
2. Install the Drivers
In order to install the proper version of the Web Drivers you need to know what version of High Sierra 10.13.x you are using and the (Build Number)
If you are not sure which build of 10.13.X you are using then open About this Mac and click on the text “Version: 10.13” to reveal the number.
See: https://support.apple.com/en-us/HT201260
Nvidia Web Drivers:
Below is a link with a list of available Nvidia Web Drivers for High Sierra.
Nvidia Web Driver Download Page (https://hackintosher.com/nvidia-drivers/)
3. Run the installer for the drivers. Reboot, and everything works!
#38822
Greetings,
I can get to the Boot Loader screen but I can't get the Mac OS utilities screen. Verbose mode says "Does printf work??"
Please help :)
#38901
"preinstall" : preinstall command not found.
Why? :cry:
palote wrote:
Fri Mar 16, 2018 9:23 am
Why? :cry:
I found the solution, you have to run XLNC
#39353
Thanks for the guide. I'm finally running my first dual-boot Windows + High Sierra with Clover PC build thanks to it.
I am not sure where to ask however but what is the difference between the Sierra/High Sierra AMD installers and vanilla installers you can get from the apple store?
#39794
Paradoxify wrote:Link not working anymore?
Link Fixed
#39808
Paradoxify wrote:
Norton287 wrote:
Sun Apr 29, 2018 7:39 pm
Link Fixed
Thanks! So I finally installed macOS. I'm stuck on the Clover installation. Your video titled, "Installing Clover for UEFI", it says that the video is unavailable... Also do you happen to have Discord?
Use the video for installing UEFI in the tutorial in the first post.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 19
Thrive Society Keto it would happens amidst a T[…]
blood sugar ultra
blood sugar ultra is a unique combination of 11 wi[…]
32-bit apps in Vanilla
Will be implemented OPEMU in the clover vanilla p[…]
Hey everyone, This is my second time trying to do[…]
