Development and testing of modified XNU Kernels for AMD CPUs on OS X
by: ithasryzen1600
#28021
So I've succesfully built a system running 12.10.6 quite stable.
One thing I noticed when I wanted to check if my system is running at it's capabilities was that the six cores of my Ryzen are running but only 6 instead of 12 threads are being used.
SMT is turned on in UEFI, I tried Voodoo TSC sync but i guess that it's not made for this purpose.
Do you have any ideas on how to enable multithreading (hyperthreading)?
by: Norton287
#28033
Have you poked around insanelymac.com, they might have some info on multithreading.
by: AlGrey
#28057
All the threads are used correctly on my side.
6 threads are always active but when required the remaining 6 kick in.
by: ithasryzen1600
#28514
@AlGrey,
you're right, my cpu just never came in that area where it had to kick in the remaining 6 threads :thumbup:
by: m4mmt
#45397
AlGrey wrote: Thu Sep 28, 2017 10:46 pm All the threads are used correctly on my side.
Hi, which program are you using to monitor the cores?
by: AlGrey
#45442
Activity Monitor
Hello, I'm currently working with my 2700x RX580 1[…]
Sorry @djseban, I missed your reply! Yes, your kil[…]
Change SMBIOS to iMacPro1,1, KPs will be gone
@teseraph , If you're still having Bluetooth i[…]
