#26433
Wow, finally got my Avid Audio Interface up and running. Because of sync issues Protools and Logic were reporting conflicts between audio and midi. I was not able to play any audio via USB even in the finder, after 10 seconds the quick view function of OSX got screwed up. Thanks a ton tikizondo94.
tikizondo94 liked this
#26436
SpritofDust wrote:
Mon Sep 04, 2017 2:06 pm
tikizondo94 wrote:
Fri Sep 01, 2017 7:35 pm
Give this one a shot. I made small edits but it may help with your timer issues.
I'm suffering same issue.
How can I fix it?
Where did you editing in config.plist?
Send me your config list. Ill see what i can do
SpritofDust liked this
#26505
tikizondo94 wrote:
Tue Sep 05, 2017 12:17 am
How can I fix it?
Here is my config.plist link.
https://www.dropbox.com/s/hln1n5attn4mv ... t.zip?dl=0
#26532
SpritofDust wrote:
Tue Sep 05, 2017 1:40 pm
How can I fix it?
See what this does for you..
#26672
SpritofDust wrote:
Thu Sep 07, 2017 12:39 pm
@tikizondo94, I still suffer this issue. Your config.plist looks like not working for my system.
Whats speed are you running your cpu you at?
#26678
tikizondo94 wrote:
Thu Sep 07, 2017 8:01 pm
My CPU running 3.8GHz. of course I edited config.plist properly.
#26713
Does the config just not load in general or it still causes the sync issues?
Hi, that sounds great. You've decided to install H[…]
Hi, I'm not sure but seems to me like your install[…]
Hi, you'd better tell us how do you prepare your b[…]
Hi, did you put your new config.plist and kexts in[…]
