by: Mic87DT
#54067
Hi, I should ask another thing.
My GPU has a problem, it works only through HDMI port.
If I connect my monitor to DVI port I see a sort of fog ^^".
Do you know why?
My GPU is an XFX Radeon RX580 with 8GB GDDR5.
I've got a very similar x570 Taichi & 3950x se[…]
This is my first build with a Ryzen and first time[…]
@iGPU , This is awesome, thanks! Your EFI confi[…]
thanks for sharing your file. I was struggling for[…]
