by: HKim
#53596
Hi guys,
I'm currently planning my first build (I had a hackintosh back in Leopard / Snow Leopard days, but that doesn't count as so much has changed).
I am reading that Navi is natively supported now. But some people are saying you still need an older card such as a RX 580 to install Catalina and then switch to the intended Navi card.
I don't have an old card and want to use a 5700XT, so my question is, can Catalina be installed with only a Navi card or is in fact an old card still necessary?
Sorry if this was already clarified elsewhere, I could not find the answer when searching.
Thanks!
Edit:
Was typing the post on my mobile, seems it was accidentally created in the post installation subforum :oops:
Could a mod move it please?
No one tried this yet? Would be really great if someone could confirm either way, as I really don't want to shell out for an old card I don't have any use for after installation...
#53710
You should be able to use it for installation yes.
by: technopath
#53728
A few of us have been having issues installing with MSI Navi cards. There's a potential workaround here: viewtopic.php?f=61&t=9832#p53708
I believe most other brands have been able to install smoothly.
Installer doesn't detect M.2 SSD
I can boot to the installer without problems, howe[…]
Of course, if all the PCIe slots are full or ina[…]
Hi all, sorry for my english ^^" I'm try to i[…]
Hi, I have same MB with 2700 CPU and RX 580 runni[…]
