#53013
Lets get to the point, I tired different visions of mac ( catalina and mojave ) ends up with the same issue ( in the pic) . but for high sierra, it works fine. i have no idea what goes wrong, please help. I tried put in another GPU ( gtx1080) but still have the same problem, so i assume is not about the gpu.
For the guide I was following(AMD Ryzen MacOS Catalina Easy Installation Guide) :
https://www.youtube.com/watch?v=fgkAsmQtjIA
updates :
I solved the problem by disable usb power and plug the usb on the motherboard .
this post can be deleted.
#53020
Gabriellam95 wrote:Lets get to the point, I tired different visions of mac ( catalina and mojave ) ends up with the same issue ( in the pic) . but for high sierra, it works fine. i have no idea what goes wrong, please help. I tried put in another GPU ( gtx1080) but still have the same problem, so i assume is not about the gpu.
Hello
Nvidia 1080 isn't supported GPU in Mojave and higher. Use modern AMD card if you want to use latest versions of MacOs.
#53021
v.osypets wrote: Sun Dec 15, 2019 6:00 am
Hello
yes thats why I am using xfx rx580 for the installation, as i mentioned in the title. 1080 just a second try. but end up with the same result .
#53027
Gabriellam95 wrote:yes thats why I am using xfx rx580 for the installation, as i mentioned in the title. 1080 just a second try. but end up with the same result .
Try to use this OpenCore config folder instead of your Clover config. Just delete everything in your EFI folder and mine setup.
https://bitbucket.org/osypets/asus-x399 ... 2-2019.zip
#53244
Apophis wrote: Sun Dec 22, 2019 9:33 pm I'm having the same issue, how did you solve it? I've also tried v.osypets efi but still fails.
Try follow this guide (ACPI section). You need to generate proper SSDT for your EC device.
Yes it's possible. I don't recommend using the sam[…]
Thanks for your post! I'm looking into replacing a[…]
Hello! I've been trying to get my OpenCore configu[…]
Fail. Not worked for nvidia gtx 1070
