#52760
Hi, Im use opencore 0.5.3 success on catalina 10.15.1(upgrade 10.15.2 beta3).
My machine:
amd ryzen 3700x (1.258v 4.2GHZ)
msi b450m mortar max
dataland rx5700
gskill snipper 3200 8g*2
bcm 94352z/dw1560
now: sleeping is ok, audio is ok, icloud/app store/.. is ok, bluetooth is ok, wifi is ok, airdrop is ok.
other I not test.
EFI Download:
EFI-OC-0.5.3.zip
Virtualization on Ryzentosh
Confirm that Virtualbox work well with Windows and[…]
OpenCore 0.5.4 vs FakeSMC?
Thanks! I'll give it a try.
please sharing your efi to me,thank you! Can you […]
