by: PRODTOLAT3
#52599
Hello please when following the steps for amd vanilla I did everything successfully but get the error "End Random seed +++++++++++"
Kexts being used: AppleMCEReporterDisabler, FakeSMC,Lilu,NullCPUPowerManagement,WhateverGreen,SSDT-ECO.aml
I started off with 2 others too but still no luck(XLNCUSBFIX,VoodooHDA)
#52600
System specs? What patches did you use?
#52602
Again... System specs?
#52612
Rebuild the USB but choose 10.15.1 (19B88)
#52650
by: ssak123
#52721
I have the same issue! I tried everything but when i try to install OSX says the same panic stack error and i should go to panic.apple.com, anyone know how to fix? *Ps: I also tried the attached appleMCEreport kext with no luck Shanee, would be great if you can assist @Shaneee
Here is my EFI:, I believe most are up-to-date kexts:
https://drive.google.com/open?id=1IfB04 ... rwml_fU0C3
My hardware:
5700xt, ryzen 5 3600, Gigabyte B450 motherboard.
Anyone know a way around?
by: PiotrPL
#52942
SImilar problem, I have:
580 gb, ryzen 5 2600, MSI Bazooka v2 B450.
Lop instalation & freez...
Best USB instalation? 10.14.6 (18G103)?
+Kexts:
Windows disk are unplugged.. When boot usb stick.
Installing Vanilla High Sierra?
Hi, I have tried for over a week (day & night)[…]
If you boot into Windows and subsequently soft-boo[…]
Hello, thanks for your reply! I am afraid the USB […]
Unable to install macOS
Hello, I've been using hackintosh a couple of ye[…]
