#52510
Good afternoon,
I'm new here and i got here because I need a little help with my vanilla installation.
First of all I did successfully install HS on that same system i now try to install Catalina.
I followed this guide to install Catalina: https://vanilla.amd-osx.com/
My System:
Ryzen 7 1800x
Asus B350 Prime Plus
Gigabyte aorus 1080ti windforce
32GB Gskill TridentZ 3600 MHZ DDR4 RAM
I did everything what's said in this guide. I use Catalina 10.15.1 (19b88) and everytime I try to install it goes the same way:
-Clover (v.5098) starts from the installation stick
-I choose to start the Catalina installer
-then a bunch of text appears
-after a short time there is a kernel panic
In my opinion it hast something to do with the ACPI because it says "Last kext loaded: apple.IMCE.blabla" (i specify it later when I am at home). I used the config.plist from the following link: https://github.com/AMD-OSX/AMD_Vanilla/tree/master/17h. Later today i can post my EFI folder so you can get a look whether I am just to dump to configure it :P.
Thank you and sorry for my bad English
sincerely
Bowet
EDIT: I added my EFI folder
#52516
Sorry for the Double Post but I just can Upload 5 attachements
#52535
Shabeeb wrote:viewtopic.php?f=61&t=9277
Ok thank you very much that worked for me, but now i don't have Ethernet-Connection in the installer and i need it. I got a realtek RTL8168 and already inserted the RTL8111.Kext into my clover folder.
Any idea how to fix this?
sincerely
bowet
#52539
you run into Kernel panic b/c Catalina and Mojave not suppported Nvidia Graphic card. u have to use AMD graphic for it. and make sure get the right Kext for your motherboard by reading your mother specs at ASus website.
#52556
Bowet wrote: Thu Nov 21, 2019 5:05 pm
sincerely
bowet
Did you figure out how to fix this?
I'm running into the same problem, got to the Catalina install okay but saying I have no Internet connection.
Using the same kext as you as this worked for me on Mojave.
Agree...so far everything seems to be working fine[…]
Hello, thanks for your reply! I am afraid the USB […]
@fozteh , included EFI and latest updates
I had already ordered Intel components to build a […]
