by: vittorioc98
#52401
Hello to everyone.. some month ago, i've installed Mac Os Mojave but i've realized that my GPU was not supported..
Some days ago i came to know that MY gpu (RX 5700XT), is supported from Catalina 15.1. Then i've tryed the installation and:
  • Firstly, after verbose, my screen went black, completely. I've fixed removing the WheatheverGreen kext.
  • Secondly, when i passed the verbose and GUI came up, my Ethernet was not rceognized: i've tryed to replace the kext with other but still doesn't work
  • Thirdly, i even got a PCI Wi-Fi card (TP-LINK ARCHER T6E 1300), even with that i tryed to insert/updated some kext but nothing..
Now i'm stucked at the installer because i can't go foreward withut a network.
If anyone have a solution.. to bypass the message or some usefull/working kext.. will be so happy xD
i'll attach my actually kext folder.
PS: i got config.plist from AMD-VanillaMaster/17th.
#52403
Use this modified RTL8111 for LAN, https://www.dropbox.com/s/fmdjt4z2objkt ... t.zip?dl=0
Remove any other network kext.
vittorioc98, joeshmoo liked this
by: vittorioc98
#52407
Shaneee wrote: Thu Nov 14, 2019 12:26 pm Use this modified RTL8111 for LAN, https://www.dropbox.com/s/fmdjt4z2objkt ... t.zip?dl=0
WOW... i've tryied 5 different kext and didn't work.. and u gave me the one that worked.. thank you man!
Shaneee liked this
@fozteh , included EFI and latest updates
Just checked on other install, not working.
I had already ordered Intel components to build a […]
yes thats why I am using xfx rx580 for the instal[…]
