by: kwankiu
#52381
I am happy to say that I got a success on editing the cpu name from 6-core intel core i5 to AMD Ryzen !
If you are using Clover,
it seems to be displayed as 'unknown' !
If you are using OpenCore,
it seems to be displayed as '6 Core Intel Core i5' !
To edit the cpu name, u will need :
- BBEdit (orginally called textwrangler) : https://www.barebones.com/products/bbedit/download.html
- An AMD Hackintosh
- macOS 10.15 Catalina
How to do :
1. Type 'sudo mount -uw /'
If your cpu is 'unknown',
Use this method :
https://github.com/corpnewt/CPU-Name
If your cpu is shown as Intel,
This will be the method :
1. Go to terminal (make sure u mount the system as read/write as I said above)
2. Enter
cp /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/en.lproj/Processors.strings ~/Desktop/
(u might need to change en.lproj to other region)
3. Open it with BBEdit and u should see the name your cpu displayed as :
For example my system show 6-Core Intel Core i5
<string>6-Core Intel Core i5</string>
<key>6-Core Intel Core i5</key>
Replace it with
<key>The Name u wanted to set</key>
4. Save it !
5. replace your modified Processors.strings to the system by going to the folder
6. Place the modified string file there !
7. reboot and enjoy
elasa, csoto09, tikizondo94 liked this
#52389
Hi , I upgrade Rx560 to Rx 5700, but can't starting catalina (10.15.1) , Could you send your EFI to my email ? (*email removed*)
#52393
I am sorry I think I made it wrong, it should be
Replace it with
<string>The Name u wanted to set</string>
#52398
Use Terminal to copy the file back,
sudo cp -Rf ~/Desktop/Processors.strings /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/en.lproj/
kwankiu, csoto09 liked this
#52489
Shaneee wrote: Thu Nov 14, 2019 10:01 am Use Terminal to copy the file back,
In my case : 3.39ghz processor how to proceed? I use the Portuguese language of Brazil.
#52517
Natanaellima wrote:In my case : 3.39ghz processor how to proceed? I use the Portuguese language of Brazil.
You'll need to follow the guide exactly but you need to edit the ".lproj" file that matches your language settings.
I use British English so I have to edit "en_GB.lproj" you will probably need to edit "pt.lproj" or "pt_PT.lproj" for Portuguese.
Where the guide says:
Try this one:
/System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/pt.lproj/
#52523
rusteswan wrote: Wed Nov 20, 2019 5:49 pm
Don´t work for me.
Try this one:
Ryzen 3900x 32 bit apps
Install a high sierra, you can run 32bit on that. […]
Drive is locked
Latest Firmware already installed on the drive. W[…]
one question @Edo did the TB works?? have you trie[…]
No need to start from scratch. Make sure you updat[…]
