by: gopal334
#52291
Still need to test what is fixed and what is broken. The upgrade itself was uneventful with OC.
#52367
Were there additional patches required? Or just a straight up update from the App Store with existing 10.15/10.15.1 install?
Enquiring mind wants to know.
by: gopal334
#52370
No additional patches required. In my case I used the released 17H patches to reboot during install. There are two reboots during install/upgrade. It was a plain update on a an existing 10.15.1 install. I did get a notification that an update is available .
by: Bensmith
#52382
Worked flawlessly for me too. Updating just like a regular Mac.
Anybody nervous to update? Don't be.
During installation it asks to do a restart, when you reboot just select the 15.2 installation (should be automatically detected).
To be honest, I don't notice any differences 'yet' between 15.1 and 15.2.
gopal334 liked this
Check my reply here out https://forum.amd-osx.co[…]
Check my reply under https://forum.amd-osx.com/v[…]
I’ve had that issue and it can be solved by […]
This method is not working on Ryzen 3700x after m[…]
