by: 233fatman
#51462
This problem has arisen from 10.14.6 to 10.15, and config is up to date.
by: Mudza
#51478
where can I download that kext file "AppleMCEReporterDisabler.kext" ??
Update :
Already found the file, and thanks now the installation run perfectly. I will report again after the installation finish
by: germano
#51480
to me this problem appears, can someone help me?
by: algady
#51500
germano wrote: Wed Oct 09, 2019 11:33 am to me this problem appears, can someone help me?
You need to add this AppleIntelMCEReporter.kext to your clover
by: bdfish1104
#51506
What drivers did you use? I do not use OsxAptioFixDrv and everything is fine.
I followed the following instruction to build my bootable USB so that I did not use OsxAptioFixDrv.
https://vanilla.amd-osx.com/setting-up- ... d-vanilla/
by: germano
#51562
my configuration:
CPU: AMD - Ryzen 7 1800x
MOB: ASRock X370 Fatal1ty Gaming X
RAM: Corsair Vengeance LPX 32 GB DDR4 3000 MHz, C15 XMP 2.0
GPU: AMD Radeon Pro WX 7100
Memory: Samsung SSD 860 EVO, 500 GB, 2.5" SATA III (Mac)
Memory: Samsung SSD 860 EVO, 250 GB, 2.5" SATA III (Win)
Memory: Hard-disk Seagate Barracuda ST2000M006 Sata III 7200rpm 64MB
system installed: Mojave 10.14.6
These are the installed drivers UEFI:
ApfsDriverLoader.efi
AptioMemoryFix-64.efi
AudioDxe.efi
DataHubDxe.efi
FSInject.efi
SMCHelper.efi
VBoxHfs.efi
Kext:
AHCI_3rdParty_SATA.kext
AHCIPortInjector.kext
AppleALC.kext
CodecCommander.kext
FakeSMC_ACPISensors.kext
FakeSMC_GPUSensors.kext
FakeSMC_LPCSensors.kext
FakeSMC_SMMSensors.kext
FakeSMC.kext
Lilu.kext
NullCPUPowerManagement.kext
RealtekRTL8111.kext
SmallTreeIntel82576.kext
USBInjectAll.kext
WhateverGreen.kext
after several attempts I came to this solution of panic:
by: Sundhar88
#51564
Put your kexts in Clover->kexts>other.
Hello! I realize this isn't quite a "Success […]
64bit app no working
I'm a few months late but I'll comment as I actual[…]
I'm trying to install Catalina 10.15.1 onto my ne[…]
