by: open_command0
#55923
Hey Guys,
so I tried installing AMD OS X with the instructions given on the Website. But I cant quite get it running and I am always hopping from one guide to the next without understanding what I am doing...
Is there any way to aquire all the neccesary kexts and all data in a Folder for my System? Or is there a nice instalation tutorial which is easy to understand?
Ryzen 3900x 32 bit apps
Install a high sierra, you can run 32bit on that. […]
Drive is locked
Latest Firmware already installed on the drive. W[…]
one question @Edo did the TB works?? have you trie[…]
No need to start from scratch. Make sure you updat[…]
