by: Sac23
#54550
hello so I have a Rog Hero Crosshair VIII with 3950x CPU
I am trying to get a bootable working but I keep either getting stuck on cant load kernel or just stuck at ++++++++ please if anyone can help that would be awesome thanks in advance
and I'm sorry if I am saying anything wrong here I'm very new here :)
optical liked this
#54556
If you are using Clover you'll need to switch to OpenCore for it to boot.
#54565
#54584
Read through the tutorial to create your own EFI. What I'm using might not work for you.
#54589
Did you include AppleALC? This will enable onboard audio but you'll need to set the layout ID. You'll need to know what Codec your motherboard uses then find it in this list, https://github.com/acidanthera/AppleALC ... ted-codecs
Once you've got it you'll see a list of available layout IDs. You'll then need to use the boot arg alcid=x, replacing x with a number. Try one at a time till you've got working audio.
#54591
You need to mount your EFI partition and add the boot arg under the NVRAM section.
You should not need the DSDT.aml nor the SSDT-EC.d[…]
Matx board? Sleep and wake is fine?)
Speak to XLNC on the Discord. It's a non Zen issue[…]
Help booting Mojave installer
OpenCore supports all version of 10.13, 10.14 and[…]
