by: Wakna
#51120
Hey guys,
I always used to hackintosh intel systems but the recent progress with AMD Vanilla make me hyped !
I'm about to buy a ryzen 3700x but as a Web/Mobile Developer I would really like to know if the virtualization works to use mobile emulators, can't find a clear awnser.
If someone knows about or can test it for me your help is precious.
**off topic**
I'm about to buy a 5700 XT too, do you think the drivers will be available on Mojave or do I have to wait for the release of Catalina and AMD patches for 10.15?
Thanks for your help
by: Sephira
#51145
Is there a reason why it wouldnt? I mean if you have a full working OSX system what would stop this from working? Current AMD chips support all the VM extensions needed for normal VM'ing.
by: Wakna
#51149
Not knowing the AMD ecosystem, I had a doubt because before installing OSX on an Intel PC, it is generally recommended to disable the virtualization to avoid conflicts. I've never had a problem with Intel virtualization (Vt-D) before, but I wanted to make sure it would work perfectly on AMD-based Hackintosh before my purchase.
by: ErikW
#51211
I have no troubles with VirtualBox, but virtualization in Docker doesn't work with their native app. Gotta use DockerMachien through a VirtualBox instance.
YMMV. I haven't tested much.
by: Wakna
#51218
Fortunately for me I do not use Docker for the moment but it can be binding if I need it for a future project. It still puts me in doubt, if you guys have Xcode installed or can download it, could you test running Simulator (IOS emulator)? Xcode comes with it and there is no need for configuration.
by: ryzen0800
#52258
I have the same concern, let me know if you found the answer ;)
by: Barbanks
#52930
I just set up an AMD Hackintosh for the sole purpose of full stack mobile dev. Unfortunately on my 2700x even with SVM enabled macOS doesn't recognize virtualization on the CPU. I haven't found any resources yet to get around this.
With that being said, if you only need to do iOS development then you're in luck; the iOS simulator doesn't need virtualization and runs great on Ryzentosh. You just can't run the Android Simulator, Docker or (I believe, haven't tried) Virtualbox.
If anyone makes any headway on this please let me know! I'd rather not have to switch to Intel.
by: Wang Zhuo
#52934
Most of the Virtual Machine related applications on macOS are based on Intel's VT-X but AMD processor only support AMD-V. If you are an android developer, Genymotion works perfectly on macOS. Xcode and its official iOS simulator is compatible with Ryzentosh.
by: Barbanks
#52952
How are the virtual device speeds for you? I downloaded the trial edition of Genymotion but each device is extremely slow.
by: awesometic
#53002
Actually, in my case, Genymotion isn't that fast I expected. Genymotion uses VirtualBox as its driver, and VirtualBox runs not bad but also not perfect.
It seems something goes wrong if I assign more than 1 core to a virtual machine. It comes slower and slower as I assigned more cores.
You won't get fan control on a hackintosh. Use you[…]
How did you find us?
Snazzy Labs video.
I solve problem black screen with rx 5700 xt, addi[…]
Yes, I'm on the latest Version 2.0: https://www.as[…]
