by: 0xPure
#10368
Hello guys!
I'm wondering if any of you is using any application for monitoring the CPU and GPU temperatures on the Sierra's system tray. I'm looking for it but not sure which one to use.
Would be good if all of you share which applications do you use for this functionality or your suggestions.
Happy hackintoshing! :mrgreen:
#10376
I use HWSensors from Slice. Be sure to customise the install and un-select the Intel CPU kext and choose the AMD one,
https://sourceforge.net/projects/hwsensors/
by: 0xPure
#10381
I tried it but is only showing me HDD temperatures. I need some plugins to display the CPU temperature but don't know where to get them.
#10386
In the installer choose the customise option. All the plugins are in there.
by: 0xPure
#10390
Yeah but to install the plugins is required to install the FakeSMC too. Is this safe? Because I'll need to remove the FakeSMC on /EFI/EFI/Clover/kext/Other
#10391
You could extract the FakeSMC and the plugins you need and put them all in EFI/Clover/Kexts/Other or I can upload them all later for you.
by: 0xPure
#10393
Shaneee wrote:You could extract the FakeSMC and the plugins you need and put them all in EFI/Clover/Kexts/Other or I can upload them all later for you.
Didn't worked :(
My steps:
1. Install HWSensor with FakeSMC and plugins.
2. Go to S/L/E, show the packages of FakeSMC and copy the plugins to /EFI/CLOVER/kexts/Other
3. Remove the FakeSMC from S/L/E
4. Reboot
After that, HWMonitor continues displaying only the temperatures of my hard disks.
#10395
Sorry that's the wrong version. Use this one. It has the CPU monitor for AMD. The CPU kext should install inside FakeSMC.kext/Contents/Plugins
https://sourceforge.net/projects/hwsensors3.hwsensors.p/https://sourceforge.net/projects/hwsensors3.hwsensors.p/
by: 0xPure
#10403
Still doesn't work :(
#10414
Are the kexts loaded? Run this in Terminal to show the non Apple loaded kexts,
kextstat | grep -v com.apple
You should not need the DSDT.aml nor the SSDT-EC.d[…]
Matx board? Sleep and wake is fine?)
Speak to XLNC on the Discord. It's a non Zen issue[…]
Help booting Mojave installer
OpenCore supports all version of 10.13, 10.14 and[…]
