by: dsalsa
#44593
Help I'm unable to mount my EFI drive to delete the appropriate file that will enable me to boot, as I'm only able to boot in same mode now. Tried the traditional method (diskutil list, mkdir /Volumes/efi, sudo mount -t msdos /dev/disk0s1 /Volumes/efi). Tried using "Clover Configurator" didn't work and I've used both methods in the past with no problem.
How to force install 10.14.1?
The Vanilla patch made updating so easy. No more r[…]
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
I have same cpu, any tips appreciated. Firm inte[…]
