by: m h
#51784
Got to the install screen where disk utility and install macos are, and after a minute it freezes completely. Tried unplugging and replugging mouse and keyboard, different usb ports, etc. Attached photo is an example of it freezing(its random)
System:
Ryzen 5 3600
Gigabyte B450M DS3H
Corsair vengeance 16 gb ddr4 3200
512gb ssd(2 seperate partitions, one for mac)
Rx 580 8 gb msi
Kexts:
Whatevergreen
Lilu
Nullcpupowermanagement
Fakesmc
AppleALC
Realtek(for ethernet)
Config.plist:
Linked in the guide i used, here: https://vanilla.amd-osx.com
by: Giuseppe Iacobucci
#51797
I have the same exact problem. Probably, it'll be a BIOS setting.
My conf is:
AMD 2920x
Gigabyte Arous XTREME x399
Corsair Vegenance LED 32GB DDR4 3600
1T m2 Samsung Evo 970
GTX 1050 TI
Reading on some forum, people have fix this problem of freeze, increasing RAM voltage, but i not try it at all cause i'm too busy.
If you find a solution, please reaply. Also i will do the same.
It's a simple fix. Open your network kext and edit[…]
Hi gm0rk, I have the same mainboard as you, an AS[…]
Use this modified RTL8111 for LAN, https://www.d[…]
alright i'll do that thanks Post Merged hello […]
