#51298
Hi guys, I'm using AMD Ryzen 5 and install Mojave, checkout the About above:
Recently I got the kernel panic but I don't know why it happens and how to fix. I need some helps.
*** Panic Report ***
Panic(CPU 2, time 3905113912463): NMIPI for unresponsive processor: TLB flush timeout, TLB state:0x0
RAX: 0x00000000ffffffff, RBX: 0xffffff81be747000, RCX: 0x000000000000c1a8, RDX: 0x00000000ffffff01
RSP: 0xffffff820e09afd0, RBP: 0xffffff820e09afe0, RSI: 0xffffff81ff8471a8, RDI: 0xffffff81ff83b000
R8:  0x0000000072c1f4dd, R9:  0x0000000000000000, R10: 0xffffff7f9c4e4568, R11: 0xffffff7f9b4598d0
R12: 0xffffff81bee77000, R13: 0xffffff820e09b2b0, R14: 0x0000000000000000, R15: 0xffffff8045a80fb0
RFL: 0x0000000000000082, RIP: 0xffffff7f9b3f7f3a, CS:  0x0000000000000008, SS:  0x0000000000000010
Backtrace (CPU 2), Frame : Return Address
0xffffff81ff37ef70 : 0xffffff8019edb00b mach_kernel : _interrupt + 0x12b
0xffffff81ff37efd0 : 0xffffff8019d5bced mach_kernel : _hndl_allintrs + 0x11d
0xffffff820e09afe0 : 0xffffff7f9b3f7f10 com.apple.kext.AMD9500Controller : __ZN21BaffinRegisterService11hwReadReg32Ej + 0x70
0xffffff820e09b010 : 0xffffff7f9b20cf69 com.apple.kext.AMDSupport : __ZN16ARegisterService9reReadRegEjj + 0x79
0xffffff820e09b050 : 0xffffff7f9b20cd6f com.apple.kext.AMDSupport : __ZN16ARegisterService15validateHWStateEjjj + 0x8f
0xffffff820e09b090 : 0xffffff7f9b3f7fb4 com.apple.kext.AMD9500Controller : __ZN21BaffinRegisterService9readReg32Ej + 0x74
0xffffff820e09b0d0 : 0xffffff7f9b20aef1 com.apple.kext.AMDSupport : __ZN14AtiFbInterrupt16readInterruptRegEj + 0x71
0xffffff820e09b100 : 0xffffff7f9b20ab98 com.apple.kext.AMDSupport : __ZN14AtiFbInterrupt9doDisableEv + 0x88
0xffffff820e09b140 : 0xffffff7f9b20aae0 com.apple.kext.AMDSupport : __ZN14AtiFbInterrupt7disableEPv + 0xc0
0xffffff820e09b180 : 0xffffff7f9c77c08e com.apple.kext.AMDFramebuffer : __ZN14AMDFramebuffer17setInterruptStateEPvj + 0xce
0xffffff820e09b1d0 : 0xffffff7f9c0c011c com.apple.kext.AMDRadeonX4000 : __ZN37AMDRadeonX4000_AMDGraphicsAccelerator26setTimestampInterruptStateEPvj + 0x62
0xffffff820e09b200 : 0xffffff7f9c10ef4a com.apple.kext.AMDRadeonX4000 : __ZN27AMDRadeonX4000_AMDHWChannel19submitCommandBufferEP30AMD_SUBMIT_COMMAND_BUFFER_INFO + 0x392
0xffffff820e09b2a0 : 0xffffff7f9c0c2882 com.apple.kext.AMDRadeonX4000 : __ZN30AMDRadeonX4000_AMDAccelChannel12submitBufferEP24IOAccelCommandDescriptor + 0x3f4
0xffffff820e09b390 : 0xffffff7f9c008f16 com.apple.iokit.IOAcceleratorFamily2 : __ZN19IOAccelFIFOChannel214submitCommandsEP24IOAccelCommandDescriptor + 0x1c2
0xffffff820e09b3d0 : 0xffffff7f9c0eb1c9 com.apple.kext.AMDRadeonX4000 : __ZN35AMDRadeonX4000_AMDCommandBufferPool12submitBufferEy + 0x109
0xffffff820e09b400 : 0xffffff7f9c0e8ce8 com.apple.kext.AMDRadeonX4000 : __ZN35AMDRadeonX4000_AMDAtomicBlitManager18endBatchSubmissionEy + 0x20
0xffffff820e09b420 : 0xffffff7f9c0cb68e com.apple.kext.AMDRadeonX4000 : __ZN31AMDRadeonX4000_AMDAccelResource6pageonEP12IOAccelEventby + 0x3dc
0xffffff820e09b4e0 : 0xffffff7f9c01e2fd com.apple.iokit.IOAcceleratorFamily2 : __ZN16IOAccelResource214pageonIfNeededEv + 0x14b
0xffffff820e09b560 : 0xffffff7f9c01ddad com.apple.iokit.IOAcceleratorFamily2 : __ZN16IOAccelResource24loadEv + 0x25
0xffffff820e09b580 : 0xffffff7f9c020382 com.apple.iokit.IOAcceleratorFamily2 : __ZN16IOAccelResource27prepareEv + 0x194
0xffffff820e09b5c0 : 0xffffff7f9c0cf8bf com.apple.kext.AMDRadeonX4000 : __ZN31AMDRadeonX4000_AMDAccelResource7prepareEv + 0x47
0xffffff820e09b5e0 : 0xffffff7f9c0ce22c com.apple.kext.AMDRadeonX4000 : __ZN31AMDRadeonX4000_AMDAccelResource12BatchPrepareEP37AMDRadeonX4000_AMDGraphicsAcceleratorPKPS_j + 0x10a
0xffffff820e09b680 : 0xffffff7f9c03dd38 com.apple.iokit.IOAcceleratorFamily2 : __ZN19IOAccelCommandQueue15coalesceSegmentEP26IOAccelCommandQueueSegmentPjP26IOAccelSegmentResourceListPK20IOAccelKernelCommandS7_ + 0x4c
0xffffff820e09b6c0 : 0xffffff7f9c03e064 com.apple.iokit.IOAcceleratorFamily2 : __ZN19IOAccelCommandQueue20processCommandBufferEjj + 0x28e
0xffffff820e09b960 : 0xffffff7f9c03f027 com.apple.iokit.IOAcceleratorFamily2 : __ZN19IOAccelCommandQueue22process_command_bufferEjj + 0x37f
0xffffff820e09b9f0 : 0xffffff7f9c03d35e com.apple.iokit.IOAcceleratorFamily2 : __ZN19IOAccelCommandQueue21submit_command_bufferEjjyy + 0xfc
0xffffff820e09ba50 : 0xffffff7f9c03d165 com.apple.iokit.IOAcceleratorFamily2 : __ZN19IOAccelCommandQueue22submit_command_buffersEPK29IOAccelCommandQueueSubmitArgs + 0x33b
0xffffff820e09baa0 : 0xffffff7f9c03c1bb com.apple.iokit.IOAcceleratorFamily2 : __ZN19IOAccelCommandQueue24s_submit_command_buffersEPS_PvP25IOExternalMethodArguments + 0xf9
0xffffff820e09bae0 : 0xffffff801a4863e8 mach_kernel : __ZN12IOUserClient14externalMethodEjP25IOExternalMethodArgumentsP24IOExternalMethodDispatchP8OSObjectPv + 0x1d8
0xffffff820e09bb30 : 0xffffff801a48f892 mach_kernel : _is_io_connect_method + 0x212
0xffffff820e09bc70 : 0xffffff8019e965c6 mach_kernel : _iokit_server_routine + 0x5e46
0xffffff820e09bd80 : 0xffffff8019db3f2c mach_kernel : _ipc_kobject_server + 0x12c
0xffffff820e09bdd0 : 0xffffff8019d8eca1 mach_kernel : _ipc_kmsg_send + 0xd1
0xffffff820e09be50 : 0xffffff8019da33be mach_kernel : _mach_msg_overwrite_trap + 0x3ce
0xffffff820e09bef0 : 0xffffff8019ec17e7 mach_kernel : _mach_call_munger64 + 0x257
0xffffff820e09bfa0 : 0xffffff8019d5c326 mach_kernel : _hndl_mach_scall64 + 0x16
         com.apple.kext.AMDSupport(2.1.1)[863E08D0-EF33-371E-B393-2C9E981CCE4D]@0xffffff7f9b1d5000->0xffffff7f9b3d6fff
            dependency: com.apple.iokit.IOACPIFamily(1.4)[3E8E9870-2E41-33F6-ACBF-35DDC08F22B5]@0xffffff7f9ac8a000
            dependency: com.apple.iokit.IOPCIFamily(2.9)[BFDEB8D4-50FE-3DDB-87B7-F6A504393830]@0xffffff7f9a695000
            dependency: com.apple.iokit.IOGraphicsFamily(530.66)[373EAB85-2C5F-3B84-B86D-421F79C47DF2]@0xffffff7f9ae2f000
            dependency: com.apple.AppleGraphicsDeviceControl(3.50.12)[5334847D-B612-3E8C-88A3-C2A5853675CD]@0xffffff7f9b165000
         com.apple.kext.AMD9500Controller(2.1.1)[D2EE149C-AE6D-3189-B62E-5D182E7F97CE]@0xffffff7f9b3f6000->0xffffff7f9b4effff
            dependency: com.apple.kext.AMDSupport(2.1.1)[863E08D0-EF33-371E-B393-2C9E981CCE4D]@0xffffff7f9b1d5000
         com.apple.iokit.IOAcceleratorFamily2(404.14)[618B24B5-1387-31FD-A7F7-53283E2C3FEA]@0xffffff7f9c005000->0xffffff7f9c0abfff
            dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[1D716047-7F62-3FFA-8C01-26C166B3739A]@0xffffff7f9ab8d000
            dependency: com.apple.iokit.IOSurface(255.6.1)[263BDC28-38C8-3995-BB6B-AD419E41C2DC]@0xffffff7f9bfe1000
            dependency: com.apple.iokit.IOReportFamily(47)[0BC9F93B-456A-3D97-BE4C-69DCBB5E8A3C]@0xffffff7f9b4fd000
         com.apple.kext.AMDRadeonX4000(2.1.1)[25F10272-62BF-31EF-813B-A3622258B230]@0xffffff7f9c0bc000->0xffffff7f9c5f4fff
            dependency: com.apple.iokit.IOAcceleratorFamily2(404.14)[618B24B5-1387-31FD-A7F7-53283E2C3FEA]@0xffffff7f9c005000
         com.apple.kext.AMDFramebuffer(2.1.1)[944BF3CB-3F16-3A7C-9CBE-93E411897E94]@0xffffff7f9c766000->0xffffff7f9c7a2fff
EOF
Here is the drivers I have in drivers64UEFI folder
ApfsDriverLoader-64.efi
AptioMemoryFix-64.efi
HFSPlus.efi
VirtualSmc.efi
And the kexts
Lilu.kext
NullCPUPowerManagement.kext
USBInjectAll.kext
VoodooHDA.kext
XHCI-unsupported.kext
NightShiftUnlocker.kext
RealtekRTL8111.kext
VirtualSMC.kext
WhateverGreen.kext
I've got a very similar x570 Taichi & 3950x se[…]
This is my first build with a Ryzen and first time[…]
@iGPU , This is awesome, thanks! Your EFI confi[…]
thanks for sharing your file. I was struggling for[…]
