by: nit34byte
#48064
Hello, I am back to hackintosh
I love that community because here you can find everything you need for a perfectly working mackintosh
Yesterday I successfully installed Mojave on my new rig
Aorus B450M Ryzen 5 1600x, 16 GB DDR4 2400 Mhz, XFX RX 580 8 GB by following AMD OS X Vanilla Tutorial
but I have a little problem.
Steam is not working in anyway and I don't know why, continue to tell me : Steam quit unexpectedly
I also tried :
MacOS Mojave 14.4
MacOS Mojave 14.5
MacOS HS 13.6
MacOS HS 13.6 with new kernel from AMD OS X
Someone know what I did wrong? thanks
Working :
BOOT ofc.
Ethernet
Audio USB-HDMI-Analogic
GPU Acceleration - RX 580 and I also tried some games to check FPS stability and passed my tests
Mouse/keyboard
USB 2.0,USB3.0,USB3.1
Siri,iCloud
NOT Working:
WiFi (I have a tp-link pci-e adapter)
GPU Fan Control (it start automatically after 50 degrees)
CPU Fan Control (I use my bios to set my cpu fan speed)
Mouse/keyboard drivers (cause is for windows only)
iMessages,FaceTime etc.
my config.plist https://pastebin.com/ge4RxYdK
kexts list I used :
FakeSMC.kext
NullCPUPowerManagement.kext
Lilu.kext
Whatevergreen.kext
RealtekRTL8111.kext
VoodooHDA.kext
and something else (I edit as soon as I come back to my pc)
Thats my crash report for steam on macOS High Sierra 10.13.6
https://pastebin.com/JeYqggKk
Hey there :) I wanna install Mojave on my PC. Im[…]
@Shaneee , Sorry dude... still didn't work. But I[…]
FX 4130?
The installer is a recovery medium. It'll downlo[…]
Which OS X is compatible to AMD A8 7600
Sierra, High Sierra, and Mojave. You can install o[…]
