by: nathanh0
#47855
Hi there!
I was able to successfully install Mojave 10.14.4 on my PC to SSD but when trying to boot with Clover to the SSD I am stuck at EndRandomSeed.
I have been through almost all of the EndRandomSeed posts, but have come up empty handed.
I know that it's related to memory.
I am using the prelinkedkernel patch method.
Motherboard: Gigabyte GA-990-FX UA3
Processor: FX8150
Video Card: NVidia GTX960 2GB
SSD: 128 GB
Memory: 32 GB [4 x 8 GB]
Before anyone comments on the video card, I know it will not perform - NVidia is dropped in Mojave.
Another thing I noticed during pre-install / reboot after install was "USBController" messages spamming with "Hardware Exception" and "attempting recovery".
Before I go and spend $600+ on an Intel, would anyone be able to help me out?
Also would anyone know which video card I should get for this motherboard that will be supported in Mojave?
Thank you!
I see now, Mojave 10.14.4 is not yet supported.
I think I'm going to just settle for High Sierra.
Hopefully I can try again later.
Hmm weird. I'm using the lastest 17h but my OpenCL[…]
Ok cool, and do I have to add the kext folder that[…]
It won't be stuck on pmtelemetry. You've posted th[…]
Installation
same here anyone got any ideas?
