by: MilkyShadilay
#53831
I can boot to the installer without problems, however I can't see my SSD (Samsung 860 EVO). It's a SATA drive so it should work out of the box. I have set the SATA mode to AHCI in UEFI.
here is my config.plist: https://pastebin.com/1f9zddMq
  • MSI B350 TOMAHAWK
  • AMD Ryzen 5 2400G
  • Sapphire Pulse Radeon RX580 4GB
  • HyperX Predator 3000MHz CL15 DDR4 16GB
  • Realtek 8111H
  • Realtek ALC892
#53837
Does Disk Utility show the drive? It needs formatted first. I have a 960 EVO working just fine.
by: MilkyShadilay
#53912
Shaneee wrote:Does Disk Utility show the drive? It needs formatted first. I have a 960 EVO working just fine.
Nope, it doesn't show up even when i enable the "show all drives" option.
#53921
Ensure that you've got SATA mode set to AHCI or that RAID is disabled on the device in the BIOS.
You should not need the DSDT.aml nor the SSDT-EC.d[…]
Matx board? Sleep and wake is fine?)
Speak to XLNC on the Discord. It's a non Zen issue[…]
Help booting Mojave installer
OpenCore supports all version of 10.13, 10.14 and[…]
