by: cedrickmapa
#52629
Hi guys i need help on my hackintosh, everything looks okay except when shutting down or restarting the displays,mouse and keyboard turns off but my system unit wont turn off even after 10 mins. I don't know where to find the issue here i tried fixshutdown in clover but to no avail
My Specs
CPU: Ryzen 7 2700
MOBO: Gigabyte b450 Aorus pro
RAM: Corsair LPX 2400mhz 8x
GPU: Asus Strix RX580 8gb
by: willeyh
#52668
Does -v echo "Recovering from Kernel Panic" when you reboot after forced shutdown?
Had a similar issue in High Sierra, was the native USB 3.0 drivers not installed.
If you go to "About this mac -> System Report - > USB" you should see your USB 3.0 Controller and connected devices.
If it´s blank then do the Native USB 3.0 install for Ryzen. Guide is in the Tutorials section.
by: cedrickmapa
#52799
well check on this. sorry for the late reply just got home from a vacation
After banging my head against the wall on a few st[…]
CPU Temperature
How to make sensors work ? I have Ryzen 7 2700
It's possible that there's an issue specific to US[…]
Ryzen 5 1600, GTX 1060, Asrock350m pro4
Hello, congratulation for your hackintosh! I just […]
