#51368
I followed each and every step of the vanilla guide and yet I am stuck in this error. Upon my research its suppose to be ethernet kext error but I tried all of kext available in the guide as well related to my chipset but failed. Even tried sudo ntpdate -u time.apple.com but says command not found. Please help.
My hardware
061-21551 - 10.14.6 macOS Mojave
Asus X399 Prime-A. Intel I211 Gigabit Ethernet
Threadripper 1920X
Gtx 1080ti
#52410
It's a simple fix. Open your network kext and edit the Info.plist. Modify the OSBundleRequired string to Root.
dunpeal liked this
Just checked on other install, not working.
@QuickTime , any chance you can share your EFI fo[…]
I had already ordered Intel components to build a […]
yes thats why I am using xfx rx580 for the instal[…]
