#51118
Hi guys do you guys have experice that the system froze in the middle when trying to select install. It does not froze for like 1 min but after that it froze.
I Was trying to format my disk but was froze before I could get into it. the mouse cant be move after one min get into this menu.
this is my system build
CPU: AMD Ryzen™ Threadripper™ 2970WX
RAM: Crucial Ballistix Sport LT 3200 MHz DDR4 DRAM Desktop Gaming Memory Single 16GB
GPU: Sapphire Radeon Rx 5700 Xt 8GB GDDR6 HDMI/ Triple DP (UEFI) PCI-E Graphics Card
MOTHERBOARD: GIGABYTE X399 AORUS Xtreme
SSD 1: Seagate FireCuda 2TB Solid State Hybrid Drive Performance SSHD
SSD 2: Seagate FireCuda 2TB Solid State Hybrid Drive Performance SSHD
any help you could give me please let me know thank you
Egress liked this
#52108
Thanks for sharing. I am having the same issue of freezing after booting up from USB successfully to MacOS Utilities. It will freeze after 10 - 20 sec.
I checked everything in BIOS following suggestions to turn off Serial port, etc, etc. Still not working.
My hardware spec:
MOBO: MSI B450 Gaming Pro Carbon
CPU: Ryzen 7 2700x
RAM: Corsair Vengeance RGB Pro 16GB
Disk: 1TB Samsung SSD 970 EVO Plus M.2 NVMe
GPU: MSI Armour RX570 4GB
Thanks to your EFI i've managed to finally put the[…]
@gbp27 , Try with this.
Use a different USB port. It's hanging on Still W[…]
Using Hackintool for USB Mapping?
Is there a downside to using Hackintool for USB ma[…]
