#51015
Hi,
I'm installing Mojave 10.14.6 on my workstation:
- CPU Ryzen Threadripper 1950x
- Asus Rog Strix X399 Egaming
- 16x4 Gb Corsair Vengeance LPX DDR4, 3000 MHz
- Samsung MZ-V7E500BW SSD 970 EVO, 500 GB NVMe
- GTX 650
- I got more 2 SSD SATA for Win 10 and Documents
Here the procedure I follow:
- I made an USB using GibMacOS tool with last Clover and Mojave 10.14.6 - https://github.com/corpnewt/gibMacOS
- I put Kernel patches: https://github.com/AMD-OSX/AMD_Vanilla/tree/master/17h -https://github.com/AMD-OSX/AMD_Vanilla
- I generate serials using https://github.com/corpnewt/GenSMBIOS and patch config.plist with iMacPro1,1 name
-On Clover Kext I put this:
FakeSMC.kext
NullCPUPowerManagement.kext
SmallTreeIntel82576.kext
I update latest BIOS on MOBO
First part of Mojave installation on SSD NVMe went fine but when I reboot from SSD to finish, installation freezes on "estimating time remaining"
I suppose it is a BIOS issue but actually I used this guide to set properly with no results https://kb.amd-osx.com/guides/HS/installing.html
Any suggestion?
Thank you very much
EDIT solution
IMPORTANT BIOS Settings:
Locate of private memory regions: Distribuited
Memory interleaving: Channel
now Mojave is installed and works with no freeze at all
Thanks Shaneee for this site that is full of important informations
Egress liked this
You'll get it recognised with full resolution bu[…]
Hi, i'm Julien from France and i'm a newcomer on r[…]
Got to the install screen where disk utility and i[…]
Hey, looking forward to seeing this link to the mo[…]
