by: sebastianmias1
#50828
I try to install Mojave 14.6 for a couple of days now and there are a few things i dont understand:
I downloaded the 10.14.6 version and used gib macos to create the installer.
Now i am supposed to change the config.plist
So i went to the Vanilla Amd Site (https://github.com/AMD-OSX/AMD_Vanilla)
There i looked and found out that i need the config plist from the "17h" folder because i have ryzen 2700
But there is also a patches.plist ?! What am i supposed to to with that :? :?
and do i have to do other things despite from getting a few kexts ?
I uploaded my EFI folder additionally...
Thanks,
Sebastian
#50829
You only need the config.plist file. Patches.plist only contains the patches if you wish to add them to your own config. You'll need Lilu.kext, WhateverGreen.kext, FakeSMC.kext, NullCPUPowerManagement.kext and RTL8111.kext.
Egress liked this
by: sebastianmias1
#50830
Okay thanks a lot for your answer.
I think i did it like you said.
But at the installer it hangs and says "Endpoint activated through Legacy Launch....."
Do you know how to get rid of that ?
Ill upload the efi folder again
#50831
Send a picture of where it's hanging... The last message isn't always the issue.
by: sebastianmias1
#50832
Okay ill attach it to my message
Thanks
Sebastian
@gbp27 , Try with this.
Use a different USB port. It's hanging on Still W[…]
Using Hackintool for USB Mapping?
Is there a downside to using Hackintool for USB ma[…]
you think u can help me too with my USB map pls ? […]
