by: sebastianmias1
#50618
Hello,
I want to install Mojave 14.6 on my PC
However im always stuck in the booting process from the installation stick
It ends at "Random Seed"
Nothing happens after that.
I add my EFI folder so you can maybe spot mistakes
I would appreciate any help
Thanks,
Sebastian
by: artouiros
#50619
You'r VirtualSMC is in a subfolder. Don't use subfolders in kext/Other. Just put all you'r .kext in kext/Other. VirtualSMC won't load like this. And I really suggest you just VirtualSMC.kext for install, without plugins. You will add them later at postinstall. Also WhatEverGreen is in a subfolder.
This is how your kext/Other should look:
Lilu.kext
NullCPUPowerManagement.kext
RealtekRTL8111.kext
VirtualSMC.kext
WhateverGreen.kext
Don't inject VooDoo at install, you don't really need it at install.
by: sebastianmias1
#50621
Thanks for answering
I did it like you said now but it stucks at the same Point:(
Maybe its something in the bios?
I couldnt find all preferences there...
by: rafazsentral
#50658
Don't know if its worth saying, but I had the same issue on a A320M-HDV with a 200GE. The problem went away after I switched to latest FakeSMC.kext + SMCHelper.efi .
Ofourse, VirtualSMC.kext needs to be removed first.
by: rajeshvora5
#50659
I am also stuck at the same point Please help
by: sebastianmias1
#50674
Thanks rafazsentral
I will try it as soon as i am back home
Its weird that this is stuck now at this point because i tried it before but there it stuck a step further (it said endpoint is reached because of legacy blabla or anything similar)
I also tried different USB ports
I only have 3.0 and 3.1 ports on my mainboard (and a usb dac)
If anybody has an idea what the problem could be i would be happy if theyd share it with us
Thanks
Sebastian
by: abheedevta
#50675
Even I am facing the same issue post following the Vanilla guide.
My config are:
Ryzen 7 2700x
MSI X470 Gaming Pro Carbon
Sapphire Radeon RX 580 Pulse
Corsair Vengeance 8GBx2
by: sebastianmias1
#50696
Mhm
There seems to be no solution.... :cry:
Help with Mojave 10.14.6
Send a picture of where it's hanging... The last m[…]
FX 4130?
The installer is a recovery medium. It'll download[…]
Hi. After I used this script and removed USBInjest[…]
can you run osx on integrated graphics just for in[…]
