#50599
Hi fellow amd-osx users. I am using Mojave 10.14.6. Everything works good but sound. I did try to install VodooHDA but it keeps glitching (but it works, sounds is ok when it doesn't glitch) and with it I cannot use AppStore and some other apps downloaded from AppStore. Here is the crashlog:
System Integrity Protection: disabled
Crashed Thread: 35 com.apple. audio. 10Thread. client
Exception Type: EXC_BAD_INSTRUCTION (SIGILL}
Exception Codes: 0x0000000600000001, @x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Illegal instruction: 4
Termination Reason: Namespace SIGNAL, Code 0x4
Terminating Process: exc handler [603]
I also did try AppleALC to make audio work, but I guess it works only for Ryzen now, at least that was stated in other thread here. Anyone else had issues with Voodoo?
I did fix this by using XLNCUSBFIX.kext from amd discord. I actually did try this fix to get my USB3.0 working. USB3.0 still don't work, but all of USB2.0 ports now work (still at 12ms/s). And for some reason it did fix appstore crashing while VoodooHDA was enabled.
Does this work for Catalina 10.15.2 booting with O[…]
Sometimes there is the requirement to install the […]
How did you find us?
Snazzy Labs video.
I solve problem black screen with rx 5700 xt, addi[…]
