#50230
Hi all,
Have a watercooled 3900x/RadeonVII build on an Asus X470-f Strix board with 32gb ram. I have done several hackintosh builds before, but all Intel. Looking to dual boot this Ryzen PC.
Error I am getting is: it is stalling apparently on the CPU stage? with an error ending in "(240s): 'AppleACPICPU' (screen shot below)
I was following the guide here: https://vanilla.amd-osx.com
I have tried 10.14.4 and 10.14.5 (version listed as supported via the latest vanilla off github)
I have the following Drivers loaded in /Clover/drivers64UEFI:
ApfsDriverLoader-54.efi
AptioMdmoryFix-64.efi
HFSPlus.efi
The following Kexts are loaded in /Clover/kexts/other:
AppleALC.kext
NullCPUPowerManagement.kext
SmallTreeIntel82576.kext
VirtualSMC.kext
Booting off a USB 3 port (not sure if that is making a difference)
My config.plist is:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>ACPI</key>
<dict>
<key>DSDT</key>
<dict>
<key>Fixes</key>
<dict>
<key>AddDTGP</key>
<false/>
<key>AddHDMI</key>
<false/>
<key>DeleteUnused</key>
<false/>
<key>FakeLPC</key>
<false/>
<key>FixAirport</key>
<false/>
<key>FixDisplay</key>
<false/>
<key>FixHDA</key>
<false/>
<key>FixHPET</key>
<false/>
<key>FixLAN</key>
<false/>
<key>FixRTC</key>
<false/>
<key>FixShutdown</key>
<true/>
<key>FixUSB</key>
<false/>
</dict>
<key>Name</key>
<string>DSDT.aml</string>
</dict>
<key>HaltEnabler</key>
<true/>
<key>SSDT</key>
<dict>
<key>EnableC6</key>
<false/>
<key>Generate</key>
<dict>
<key>CStates</key>
<false/>
<key>PStates</key>
<false/>
</dict>
</dict>
</dict>
<key>Boot</key>
<dict>
<key>Arguments</key>
<string>-v npci=0x2000</string>
<key>DefaultLoader</key>
<string>boot.efi</string>
<key>DefaultVolume</key>
<string>LastBootedVolume</string>
<key>Legacy</key>
<string>PBR</string>
<key>NeverHibernate</key>
<true/>
<key>Timeout</key>
<integer>-1</integer>
</dict>
<key>BootGraphics</key>
<dict>
<key>EFILoginHiDPI</key>
<integer>1</integer>
<key>UIScale</key>
</dict>
<key>CPU</key>
<dict>
<key>C6</key>
<false/>
<key>UseARTFrequency</key>
<false/>
</dict>
<key>Devices</key>
<dict>
<key>Audio</key>
<dict>
<key>AFGLowPowerState</key>
<true/>
<key>ResetHDA</key>
<true/>
</dict>
<key>ForceHPET</key>
<false/>
<key>HDMIInjection</key>
<false/>
<key>InjectHDMI</key>
<false/>
<key>InjectLAN</key>
<false/>
<key>LANInjection</key>
<true/>
<key>USB</key>
<dict>
<key>AddClockID</key>
<false/>
<key>FixOwnership</key>
<false/>
<key>Inject</key>
<true/>
</dict>
</dict>
<key>GUI</key>
<dict>
<key>EmbeddedThemeType</key>
<string>Dark</string>
<key>Hide</key>
<array>
<string>Preboot</string>
<string>Legacy</string>
</array>
<key>KbdPrevLang</key>
<true/>
<key>Language</key>
<string>en:0</string>
<key>Mouse</key>
<dict>
<key>Enabled</key>
<true/>
</dict>
<key>Scan</key>
<true/>
<key>TextOnly</key>
<true/>
<key>Theme</key>
<string>embedded</string>
</dict>
<key>Graphics</key>
<dict>
<key>Inject</key>
<dict>
<key>ATI</key>
<false/>
<key>NVidia</key>
<false/>
</dict>
<key>RadeonDeInit</key>
<false/>
</dict>
<key>KernelAndKextPatches</key>
<dict>
<key>AppleRTC</key>
<true/>
<key>KernelCpu</key>
<false/>
<key>KernelToPatch</key>
<array>
<dict>
<key>Comment</key>
<string>Disable panic kext logging on 10.13 Release kernel</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
igKEwHRE
</data>
<key>MatchOS</key>
<string>10.13.x</string>
<key>Replace</key>
<data>
igKEwOtE
</data>
</dict>
<dict>
<key>Comment</key>
<string>Disable panic kext logging on 10.14 - 10.14.3 Release kernel</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
igKEwHRC
</data>
<key>MatchOS</key>
<string>10.14.1,10.14.2,10.14.3</string>
<key>Replace</key>
<data>
igKEwOtC
</data>
</dict>
<dict>
<key>Comment</key>
<string>Disable panic kext logging on 10.14 Release kernel</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
AIoChMB0
</data>
<key>MatchOS</key>
<string>10.14.4,10.14.5</string>
<key>Replace</key>
<data>
AIoChMDr
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - commpage_populate -remove rdmsr</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
uaABAAAPMg==
</data>
<key>MatchOS</key>
<string>10.13.6,10.14.x</string>
<key>Replace</key>
<data>
Dx+AAAAAAA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpu_topology_sort -disable _x86_validate_topology</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
6Ar2//+c
</data>
<key>MatchOS</key>
<string>10.13.6</string>
<key>Replace</key>
<data>
Dx9EAACc
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
6Kn1//8=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
Dx9EAAA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
6Jn1//8=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
Dx9EAAA=
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_cache_info - cpuid 0x8000001D instead 0</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
McAx2zHJMdIPokGJxkGJ0YM9ygWNAAB0GEiNPZKSXwAx
9jHAQYnIRInyidno6IlYAEGD/gQPgvoBAABFMfbrDGYP
H4QAAAAAAA==
</data>
<key>MatchBuild</key>
<string>17G65,17G66</string>
<key>MatchOS</key>
<key>Replace</key>
<data>
uB0AAIAx2zHJMdIPokGJxkGJ0YM9xwWNAAB0G0iNPY+S
XwC+HQAAgDHAQYnIRInyidno4olYAEGD/gQPgvQBAABF
MfbrBg8fAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
McAx2zHJMdIPokGJxkGJ0YM9yu2MAAB0GEiNPQ+GXwAx
9jHAQYnIRInyidno2HpYAEGD/gQPgvoBAABFMfbrDGYP
H4QAAAAAAA==
</data>
<string>17G5019</string>
<key>MatchOS</key>
<key>Replace</key>
<data>
uB0AAIAx2zHJMdIPokGJxkGJ0YM9x+2MAAB0G0iNPQyG
XwC+HQAAgDHAQYnIRInyidno0npYAEGD/gQPgvQBAABF
MfbrBg8fAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
McAx2zHJMdIPokGJxkGJ0YM9yv2MAAB0GEiNPd+JXwAx
9jHAQYnIRInyidnoqH5YAEGD/gQPgvoBAABFMfbrDGYP
H4QAAAAAAA==
</data>
<string>17G6029,17G6030</string>
<key>MatchOS</key>
<key>Replace</key>
<data>
uB0AAIAx2zHJMdIPokGJxkGJ0YM9x/2MAAB0G0iNPdyJ
XwC+HQAAgDHAQYnIRInyidnoon5YAEGD/gQPgvQBAABF
MfbrBg8fAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
McAx2zHJMdIPokGJxkGJ0YM92gaNAAB0GEiNPRmWXwAx
9jHAQYnIRInyidnouIpYAEGD/gQPgvoBAABFMfbrDGYP
H4QAAAAAAA==
</data>
<string>17G7024</string>
<key>MatchOS</key>
<key>Replace</key>
<data>
uB0AAIAx2zHJMdIPokGJxkGJ0YM91waNAAB0G0iNPRaW
XwC+HQAAgDHAQYnIRInyidnosopYAEGD/gQPgvQBAABF
MfbrBg8fAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
McAx2zHJMdIPokGJxkGJ0YM9+kGYAAB0GEiNPSvZZwAx
9jHAQYnIRInyidno2CxgAEGD/gQPgvsBAABFMfbrDGYP
H4QAAAAAAA==
</data>
<key>MatchOS</key>
<string>10.14.1</string>
<key>Replace</key>
<data>
uB0AAIAx2zHJMdIPokGJxkGJ0YM990GYAAB0G0iNPSjZ
ZwC+HQAAgDHAQYnIRInyidno0ixgAEGD/gQPgvUBAABF
MfbrBg8fAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
McAx2zHJMdIPokGJxkGJ0YM9SiSYAAB0GEiNPQvGZwAx
9jHAQYnIRInyidnoWBpgAEGD/gQPgvsBAABFMfbrDGYP
H4QAAAAAAA==
</data>
<key>MatchOS</key>
<string>10.14.3</string>
<key>Replace</key>
<data>
uB0AAIAx2zHJMdIPokGJxkGJ0YM9RySYAAB0G0iNPQjG
ZwC+HQAAgDHAQYnIRInyidnoUhpgAEGD/gQPgvUBAABF
MfbrBg8fAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
McAx2zHJMdIPokGJxoM9re2XAAB0G0GJ0UiNPRehZwAx
9jHAQYnIRInyidnoWP1fAEGD/gQPgvgBAABFMfbrDGYP
H4QAAAAAAA==
</data>
<key>MatchOS</key>
<string>10.14.4</string>
<key>Replace</key>
<data>
uB0AAIAx2zHJMdIPokGJxkGJ0YM9p+2XAAB0G0iNPRSh
ZwC+HQAAgDHAQYnIRInyidnoUv1fAEGD/gQPgvUBAABF
MfbrBg8fAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
McAx2zHJMdIPokGJxoM9JWKYAAB0G0GJ0UiNPRy0ZwAx
9jHAQYnIRInyidnoiBBgAEGD/gQPgvgBAABFMfbrDGYP
H4QAAAAAAA==
</data>
<key>MatchOS</key>
<string>10.14.5</string>
<key>Replace</key>
<data>
uB0AAIAx2zHJMdIPokGJxkGJ0YM9H2KYAAB0G0iNPRm0
ZwC+HQAAgDHAQYnIRInyidnoghBgAEGD/gQPgvUBAABF
MfbrBg8fAA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_cache_info - cpuid 0x8000001D instead 4</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
uAQAAABEifFEiQ==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uB0AAIBEifFEiQ==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_cache_info - don't set cpuid_cores_per_package</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
wega/8A=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
Dx8A6wY=
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_generic_info - remove wrmsr</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
uYsAAAAxwDHSDzA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
Zg8fhAAAAAAAZpA=
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_generic_info - set microcode=186</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
uYsAAAAPMg==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uroAAABmkA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_generic_info - set flag=1</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
uRcAAAAPMsHqEoDiBw==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
sgFmDx+EAAAAAABmkA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_generic_info - disable check to allow leaf7</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
ADoPgg==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
AAAPgg==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_info - GenuineIntel to AuthenticAMD </string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
R2VudWluZUludGVsAA==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
QXV0aGVudGljQU1EAA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_cpufamily - force CPUFAMILY_INTEL_SKYLAKE </string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
MduAPbgLjQAGdVw=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
u58h/DfpXQAAAJA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
MduAPbjzjAAGdVw=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
u58h/DfpXQAAAJA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
MduAPbgDjQAGdVw=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
u58h/DfpXQAAAJA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
MduAPagMjQAGdVw=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
u58h/DfpXQAAAJA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
MduAPehHmAAGdVw=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
u58h/DfpXQAAAJA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
MduAPTgqmAAGdVw=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
u58h/DfpXQAAAJA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
MduAPZjzlwAGdVw=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
u58h/DfpXQAAAJA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
MduAPchomAAGdVw=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
u58h/DfpXQAAAJA=
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - cpuid_set_info - ryzen cores and logicals count</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
PexeO1d0Gz28T+p4dTaLBcgKjQCJBYoLjQCLDcAKjQDr
Frk1AAAADzIPt8jB6BCD4A+JBWwLjQCJDWoLjQCFwHVK
6zC5NQAAAA8ySMHiIInBSAnRuQEAAQAPRcgPt9GJyMHo
EIkFOguNAIkVOAuNAIXAdRiLBWIKjQCJBSQLjQCLBVoK
jQCJBRwLjQA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uAgAAIAx2zHJMdIPokGJwEGJzkGJ0YM97wuNAAB0G2YP
H4QAAAAAAGYPH4QAAAAAAGYPH4QAAAAAAEUPtvZB/8a4
HgAAgDHbMckx0g+iQYnAQYnRZg8fhAAAAAAAD7bP/8Ex
0kSJ8PfxiQVtCo0ARIk1agqNAIM9JwuNAAB1DYkFHwuN
AESJNRwLjQA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
PexeO1d0Gz28T+p4dTaLBcjyjACJBYrzjACLDcDyjADr
Frk1AAAADzIPt8jB6BCD4A+JBWzzjACJDWrzjACFwHVK
EIkFOvOMAIkVOPOMAIXAdRiLBWLyjACJBSTzjACLBVry
jACJBRzzjAA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uAgAAIAx2zHJMdIPokGJwEGJzkGJ0YM97/OMAAB0G2YP
0kSJ8PfxiQVt8owARIk1avKMAIM9J/OMAAB1DYkFH/OM
AESJNRzzjAA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
PexeO1d0Gz28T+p4dTaLBcgCjQCJBYoDjQCLDcACjQDr
Frk1AAAADzIPt8jB6BCD4A+JBWwDjQCJDWoDjQCFwHVK
EIkFOgONAIkVOAONAIXAdRiLBWICjQCJBSQDjQCLBVoC
jQCJBRwDjQA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uAgAAIAx2zHJMdIPokGJwEGJzkGJ0YM97wONAAB0G2YP
0kSJ8PfxiQVtAo0ARIk1agKNAIM9JwONAAB1DYkFHwON
AESJNRwDjQA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
PexeO1d0Gz28T+p4dTaLBbgLjQCJBXoMjQCLDbALjQDr
Frk1AAAADzIPt8jB6BCD4A+JBVwMjQCJDVoMjQCFwHVK
EIkFKgyNAIkVKAyNAIXAdRiLBVILjQCJBRQMjQCLBUoL
jQCJBQwMjQA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uAgAAIAx2zHJMdIPokGJwEGJzkGJ0WYPH4QAAAAAAGYP
0kSJ8PfxiQVdC40ARIk1WguNAIM9FwyNAAB1DYkFDwyN
AESJNQwMjQA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
PexeO1d0Gz28T+p4dSaLBfhGmACJBbpHmACLDfBGmADr
OLk1AAAADzIPt8jB6BCD4A/rILk1AAAADzJIweIgicFI
CdG6AQABAA9F0A+3yonQwegQiQV6R5gAiQ14R5gAhcB0
Gg==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uAgAAIAx2zHJMdIPokGJwEGJzkGJ0UUPtvZB/8a4HgAA
gDHbMckx0g+iQYnAQYnRDx9EAAAPts//wTHSRInw9/GJ
BcVGmABEiTXCRpgAgz1/R5gAAHUNiQV3R5gARIk1dEeY
AA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
PexeO1d0Gz28T+p4dSaLBUgpmACJBQoqmACLDUApmADr
CdG6AQABAA9F0A+3yonQwegQiQXKKZgAiQ3IKZgAhcB0
Gg==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
BRUpmABEiTUSKZgAgz3PKZgAAHUNiQXHKZgARIk1xCmY
AA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
PexeO1d0Gz28T+p4dSaLBafylwCJBWnzlwCLDZ/ylwDr
CdG6AQABAA9F0A+3yonQwegQiQUp85cAiQ0n85cAhcB0
Gg==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
BXTylwBEiTVx8pcAgz0u85cAAHUNiQUm85cARIk1I/OX
AA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
PexeO1d0Gz28T+p4dSaLBddnmACJBZlomACLDc9nmADr
CdG6AQABAA9F0A+3yonQwegQiQVZaJgAiQ1XaJgAhcB0
Gg==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
BaRnmABEiTWhZ5gAgz1eaJgAAHUNiQVWaJgARIk1U2iY
AA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - i386_init - remove rdmsr</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
uZkBAAAPMkjB4iCJxkgJ1rmYAQAADzJIweIgicBICcK/
WAIxBTHJRTHA
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
Zg8fhAAAAAAAZg8fhAAAAAAAZg8fhAAAAAAAZg8fhAAA
AAAAZg8fRAAA
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - tsc_init - replace skylake with zen</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RIug0AEAAIuY1AEAAEiNPeuNXgDo2gMAAEiFwLkANm4B
SA9FyEiJyEkPr8RFMf8x0kj380iJBQCrhQBIiQUhq4UA
SLrbNLbXgt4bQ0iJyEj34kjB6hJpwkBCDwApwUiNPaeN
XgAxwInWicpMieFJidjobTNXAEiLHeaqhQA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uWQAAcAPMg+2yInGwe4Ig+Y/RTH/MdJIichI9/ZIicZI
acYAwusLSAH2SIkFCquFADHSSPf2SInDSIkdI6uFAEiJ
NQyrhQBmDx+EAAAAAABmDx+EAAAAAABmDx+EAAAAAABm
Dx+EAAAAAABmDx+EAAAAAABmDx+EAAAAAAA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RIug0AEAAIuY1AEAAEiNPceBXgDo2gMAAEiFwLkANm4B
SA9FyEiJyEkPr8RFMf8x0kj380iJBQCThQBIiQUhk4UA
SLrbNLbXgt4bQ0iJyEj34kjB6hJpwkBCDwApwUiNPYOB
XgAxwInWicpMieFJidjoXSRXAEiLHeaShQA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
acYAwusLSAH2SIkFCpOFADHSSPf2SInDSIkdI5OFAEiJ
NQyThQBmDx+EAAAAAABmDx+EAAAAAABmDx+EAAAAAABm
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RIug0AEAAIuY1AEAAEiNPZeFXgDo2gMAAEiFwLkANm4B
SA9FyEiJyEkPr8RFMf8x0kj380iJBQCjhQBIiQUho4UA
SLrbNLbXgt4bQ0iJyEj34kjB6hJpwkBCDwApwUiNPVOF
XgAxwInWicpMieFJidjoLShXAEiLHeaihQA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
acYAwusLSAH2SIkFCqOFADHSSPf2SInDSIkdI6OFAEiJ
NQyjhQBmDx+EAAAAAABmDx+EAAAAAABmDx+EAAAAAABm
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RIug2AEAAIuY3AEAAEiNPd+QXgDo2gMAAEiFwLkANm4B
SA9FyEiJyEkPr8RFMf8x0kj380iJBWiqhQBIiQWJqoUA
SLrbNLbXgt4bQ0iJyEj34kjB6hJpwkBCDwApwUiNPZuQ
XgAxwInWicpMieFJidjorTJXAEiLHU6qhQA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
acYAwusLSAH2SIkFcqqFADHSSPf2SInDSIkdi6qFAEiJ
NXSqhQBmDx+EAAAAAABmDx+EAAAAAABmDx+EAAAAAABm
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RIug0AEAAIuY1AEAAEiNPWqsZgDo8AMAAEiFwLkANm4B
SA9FyEiJyEkPr8Qx0kj380iJBenFkABIiQUKxpAASLrb
NLbXgt4bQ0iJyEj34kUx/0jB6hJpwkBCDwApwUiNPSas
ZgAxwInWicpMieFJidjoQ6teAEiLHczFkAA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
acYAwusLSAH2SIkF8MWQADHSSPf2SInDSIkdCcaQAEiJ
NfLFkABmDx+EAAAAAABmDx+EAAAAAABmDx+EAAAAAABm
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RIug0AEAAIuY1AEAAEiNPTqZZgDo8AMAAEiFwLkANm4B
SA9FyEiJyEkPr8Qx0kj380iJBSmokABIiQVKqJAASLrb
NLbXgt4bQ0iJyEj34kUx/0jB6hJpwkBCDwApwUiNPfaY
ZgAxwInWicpMieFJidjos5heAEiLHQyokAA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
acYAwusLSAH2SIkFMKiQADHSSPf2SInDSIkdSaiQAEiJ
NTKokABmDx+EAAAAAABmDx+EAAAAAABmDx+EAAAAAABm
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
SInISQ+vx0Ux7THSSff0SInGSIkFA2eQAEi62zS214Le
G0NIichI9+JIiTUUZ5AASMHqEmnCQEIPACnBSI09QWpm
ADHAidaJykyJ+U2J4OjgcF4ASIsd6WaQAA==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
uWQAAcAPMg+2yInGwe4Ig+Y/MdJIichI9/ZIicZIaf4A
wusLSAH2SIk97maQADHSSIn4SPf2SInDSIkdBGeQAEiJ
Ne1mkABmDx+EAAAAAABmDx+EAAAAAABmkA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
SInISQ+vx0Ux7THSSff0SInGSIkFm9CQAEi62zS214Le
G0NIichI9+JIiTWs0JAASMHqEmnCQEIPACnBSI09onVm
ADHAidaJykyJ+U2J4OjQd14ASIsdgdCQAA==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
wusLSAH2SIk9htCQADHSSIn4SPf2SInDSIkdnNCQAEiJ
NYXQkABmDx+EAAAAAABmDx+EAAAAAABmkA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - tsc_init - replace skylake with zen part 2</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RIu70AEAAESLo9QBAAA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
SInY6UACAABmDx9EAAA=
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RIu72AEAAESLo9wBAAA=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - tsc_init - use TSC calculated from MSR</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
SIkFlGWQAA==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
TIkllGWQAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
SIkFLM+QAA==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
TIklXc+QAA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - lapic_init - remove version check and panic</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
JfwAAACD+BM=
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
JfAAAADrI5A=
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - lapic_interrupt - skip checks and prevent panic</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
gz2UlnAAAHQK
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
60gPH4AAAAAA
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
gz2UfnAAAHQK
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
60gPH4AAAAAA
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
gz2UjnAAAHQK
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
60gPH4AAAAAA
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
gz3UlXAAAHQK
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
60gPH4AAAAAA
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
gz2UmHsAAHQK
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
60gPH4AAAAAA
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
gz3UensAAHQK
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
60gPH4AAAAAA
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
gz3VWHsAAHQK
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
60gPH4AAAAAA
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
gz0VwXsAAHQK
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
60gPH4AAAAAA
</data>
</dict>
<dict>
<key>Comment</key>
<string>algrey - mtrr_update_action - fix PAT</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
icCB4v//8P+BygAAAQC5dwIAAA==
</data>
<key>MatchOS</key>
<string>10.13.6,10.14.1,10.14.3</string>
<key>Replace</key>
<data>
uXcCAAC4BgEHALoGAQcADx9AAA==
</data>
</dict>
<dict>
<key>Comment</key>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
icCB4v//AP+BygAAAQC5dwIAAA==
</data>
<key>MatchOS</key>
<key>Replace</key>
<data>
</data>
</dict>
</array>
</dict>
<key>RtVariables</key>
<dict>
<key>BooterConfig</key>
<string>0x2A</string>
<key>CsrActiveConfig</key>
<string>0x67</string>
<key>ROM</key>
<string>UseMacAddr0</string>
</dict>
<key>SMBIOS</key>
<dict>
<key>BiosReleaseDate</key>
<string>09/17/2018</string>
<key>BiosVendor</key>
<string>Apple Inc.</string>
<key>BiosVersion</key>
<string>IM142.88Z.0131.B00.1809171347</string>
<key>Board-ID</key>
<string>Mac-27ADBB7B4CEE8E61</string>
<key>BoardManufacturer</key>
<key>BoardSerialNumber</key>
<string>D25543501CDF8YLJA</string>
<key>BoardType</key>
<integer>10</integer>
<key>BoardVersion</key>
<string>1.0</string>
<key>ChassisAssetTag</key>
<string>iMac-Aluminum</string>
<key>ChassisManufacturer</key>
<key>ChassisType</key>
<string>0x0D</string>
<key>EfiVersion</key>
<string>133.0.0.0.0</string>
<key>Family</key>
<string>iMac</string>
<key>FirmwareFeatures</key>
<string>0xE00FE137</string>
<key>FirmwareFeaturesMask</key>
<string>0xFF1FFF3F</string>
<key>LocationInChassis</key>
<string>Part Component</string>
<key>Manufacturer</key>
<key>PlatformFeature</key>
<string>0x01</string>
<key>ProductName</key>
<string>iMac14,2</string>
<key>SerialNumber</key>
<string>D25QLLYHF8JC</string>
<key>SmUUID</key>
<string>7A804573-BE42-4831-BE3B-35A97DFE48C7</string>
<key>Trust</key>
<true/>
<key>Version</key>
</dict>
<key>SystemParameters</key>
<dict>
<key>InjectKexts</key>
<string>Yes</string>
<key>InjectSystemID</key>
<true/>
</dict>
</dict>
</plist>
Pic of the build attached
Error screenshot added
FriedEngineer liked this
I need your advice
High Sierra. The GPU is holding you back.
Thought my experience would be a positive addition[…]
https://forum.amd-osx.com/viewtopic.php?f=61&am[…]
Comp Check
Hello forum, I have a build with the following co[…]
