#49869
Hello! I’m trying to install OS X from this tutorial https://hack.slim.ovh/mojave
Right now i launched with the default boot arguments and i see a prohibited sign, but text like AppleUSBHostController::hardwareExceptionThreadCallGated: attempting recovery
Keeps appearing.
Should i just wait and continue? Or maybe i should try different args? Thanks for help.
Edit: i've got past that. I hot-swap my pendrive to a USB 3.0 slot and it works, but after it loads for a while i just get a black screen.
#49876
alhermoar wrote:
Thu Jun 20, 2019 3:04 pm
Hi, I would install using the latest guide, it should be much simpler:
https://vanilla.amd-osx.com/
I've fixed all of this, but i have a black screen after the text. No mac appears.
edit: i have a rx 570 8GB and i'm using the HDMI port
edit 2: i've found this post viewtopic.php?p=49618#p49618 where someone is using the same GPU. Their issue was fixed by using DisplayPort. However, i do not unfortunately have any DP monitors, and want to ask - would DVI work, or do i need to buy an adapter?
Having the same issue. Built this hackintosh speci[…]
Thanks so much for the response. I think I will […]
I have the same problem, when i boot from the USB […]
Hi everyone, i have successfully completed my Cata[…]
