by: theevilbluez
#49860
I'm Hav these specs:
Motherboard: Gigabyte A320M-S2H
Processor: AMD A10 9700
Graphic Card: Radeon R7 (Integrated)
Ram: 4GB
For first, my system is compatible with MacOS? I already have MacOS Mojave in my notebook. In my PC i can't install, i tried install Mojave, because when open the "Disk Utility" doesn't show my HDD when i click in "show all devices", only show pendrive in USB and my external HDD on the USB.
I used the config.plist for my processor and i have the drivers64.UEFI.
Someone can help me?
by: alhermoar
#49884
If the disk is not showing up, in the same sceen where you choose to install, use DiskUtil instead, make sure the disk where you want to install Mojave to is using APFS as the file system. Otherwise, just choose the disk you want and click erase, it will format your drive accordingly.
Having the same issue. Built this hackintosh speci[…]
Thanks so much for the response. I think I will […]
I have the same problem, when i boot from the USB […]
Hi everyone, i have successfully completed my Cata[…]
