#49732
Hi folks. Ive had my PC for over a year now and I've tried at least a dozen different tutorials and gone through a bunch of weird fixes and solutions and whatnot, but I still haven't gotten macOS to boot past the first minutes of the installer at best.
I realise that some configurations are less compatible than others, and that AMD is much harder to work with to begin with. I just want my Mac apps and some Handoff stuff to work on my computer. Im willing to change components if it helps. Any help is greatly appreciated.
Here is my spec list generated by Steam. I deleted some lines to save space.
Computer Information:
    Manufacturer:  MSI
    Model:  MS-7A37
Processor Information:
    CPU Vendor:  AuthenticAMD
    CPU Brand:  AMD Ryzen 5 2600X Six-Core Processor
    CPU Family:  0x17
    CPU Model:  0x8
    CPU Stepping:  0x2
    CPU Type:  0x0
    Speed:  3600 Mhz
    12 logical processors, 6 physical processors
    HyperThreading:  Supported
    FCMOV:  Supported
    SSE2, SSE3, SSSE3, SSE4a, SSE41, SSE42:  Supported
    AES:  Supported
    AVX:  Supported
    CMPXCHG16B:  Supported
    LAHF/SAHF:  Supported
    PrefetchW:  Unsupported
Video Card:
    Driver:  Radeon RX 580 Series
    DirectX Driver Name:  aticfx32.dll
    Driver Version:  25.20.15011.1004
    DirectX Driver Version:  25.20.15011.1004
    Driver Date: 1 9 2019
    OpenGL Version: 4.6
    Desktop Color Depth: 32 bits per pixel
    Monitor Refresh Rate: 59 Hz
    DirectX Card: Radeon RX 580 Series
    VendorID:  0x1002
    DeviceID:  0x67df
    Revision:  0xe7
Memory:
    RAM:  16335 Mb
	I'm using two 8GB HyperX Fury dims
Bluetooth at Login?
Hello everyone, Long time lurker first time poste[…]
Hi Is it able to sleep and wake properly? Thanks
Yes i have, and the error disappeared. did yo[…]
[email protected]: AppleUSBEHCI::RestartUSBBus: USBS[…]
