#49584
Hi everyone, I have Vanilla AMD Mojave machine, everything is working quite good. But the the Native Access app (to download my instruments) cannot install any instrument from library. macOS says these instruments are 32bit app. I think Native Access can't detect the CPU architecture and select the default installer, which include both Windows' exe file and PKG file, and that PKG file is 32bit.
My Macbook and Windows 10 are still working but the hackintosh.
Anyone have idea?
(And sorry for my bad English)
#49652
Mojave only support for 64bit if u are using 32bit stay away from Mojave and I don't know why so many app developer doesn't want to realease update for 64 bit though.
Have you installed NullCPUPowerManagement.kext? In[…]
I have the same hardware with gtx 1060 graphics. A[…]
Not microphone...micro ATX...I had ASRock X570 Pro[…]
Specs: CPU: AMD Ryzen 9 3900x Motherboard: Asus […]
