by: pizzuka
#48134
Hi there!
I've installed with success mojave 10.14.1.. in a future i'll upgrade it, but i have an issue with parallels (ye.. i need windows too)
i cannot intall windows, every times Crash all..
any idea?
by: alphaqt
#48135
I have made multiple attempts to get parallels to work on both 10.14.1 and 10.14.4. I thought it may be related to not having WiFi and BT working. But even with that working, parallels still freezes when starting up.
In the logs it appears to be something related to the Network settings.
When I looked on various forums, I have not found anyone that seems to have had success with Hackintosh Parallels (at least recently)
by: matheusmm
#48137
I tried and had problems with Parallels too. OSX version 10.14.1 on AMD. I installed Virtualbox instead and it works very well with guest additions and extension pack.
by: pizzuka
#48215
matheusmm wrote:I tried and had problems with Parallels too. OSX version 10.14.1 on AMD. I installed Virtualbox instead and it works very well with guest additions and extension pack.
what addition? yesterday i tried but i Fail </3
by: matheusmm
#48218
make sure you have CPU virtualization support and IOMMU enabled on your BIOS, it worked for me after doing this.
VirtualBox and extension pack can be downloaded here:
https://www.virtualbox.org/wiki/Downloads
Hi, that sounds great. You've decided to install H[…]
Hi, I'm not sure but seems to me like your install[…]
Hi, you'd better tell us how do you prepare your b[…]
Hi, did you put your new config.plist and kexts in[…]
