#48006
Did all the instructions to prepare the usb drive for install. Went into the usb installer.. the monitor begins to blink... I can see the apple screen come up and then the language selector.. then the screen blinks from black to a distorted image about 6 times, then the computer restarts. Im using a AMD Ryzen 5 2600x, B450 msi board, and Nvidia Gt710 video card. Can anybody help?
Solved it on my own... looks like it doesnt like trying to emulate the resolution on my widescreen monitor during the install..... went to a standard monitor eliminated the flashing and blinking.. however the computer still reboots... working on that now.
ok... reboot issue fixed.. I went back and created the newest Mojave install without the recovery command.. and this fixed my reboot during setup issue. I installed the 10.5 install just fine. Now having trouble with clover and no wifi/bluetooth... but I'm far enough to stop until morning.
Hmm weird. I'm using the lastest 17h but my OpenCL[…]
Ok cool, and do I have to add the kext folder that[…]
It won't be stuck on pmtelemetry. You've posted th[…]
Installation
same here anyone got any ideas?
