by: KraK_cz
#47980
Hello,
Today I installed Mojave 10.14.1 and also with AMD Vanilla Clover Patches.
I was following this nice tutorial: https://www.youtube.com/watch?v=GZ_72oP58mY
And OS said that there is new version So I looked at comments under the video and some guy wrote that updating to newest version was ok.
So I installed it. It take around 15min to install and after 2 reboots I get stuck on this:
kextd stall[0], (60s): 'AppleGraphicsDeviceControlPlugin', 'IOResources'
An image is in attachments.
Thank you for the response.
First you should post what guide you followed if a[…]
when boot EFI windows bootloader(bootmgfw.efi) rea[…]
Parallels?
I tried and had problems with Parallels too. OSX […]
you just need RealtekRTL8111.kext for lan to work
